Beogram 4500 tonearm adjustment
Old 21st February 2010, 07:42 PM   #1
waverider is offline waverider  United States
Default Beogram 4500 tonearm adjustment
The turntable belongs to my mother in-law. Looks to be in mint condition except for recent destruction of the cantilever arm of the cartridge (MMC-5). It can be used in automatic or semi-automatic mode. Semi-automatic mode works OK: eyeball the lead-in groove and drop the tone arm using the tone arm position controls < > located next to the on/off (or play/stop) button.
The automatic mode does not work; the default loading position of the tonearm is off by perhaps a millimeter or two at most. And for my mother in law this is a huge problem; using the TT manually (as a workaround) is not an option. I have the turntable on my workbench. She has called four times in the last 90 minutes.
Any help with fixes/schematics appreciated.
Doug
Old 10th September 2010, 10:53 AM   #2
Boydk is offline Boydk  Denmark
Waverider.......
Take off the platter and the black plastic underneath it. YouŽll see a plastic gear wheel with two solenoids. Under this wheel thereŽs a smaller wheel with an excentric screw in it. Turning this screw will get the arm to settle further in/out.
Old 10th September 2010, 05:25 PM   #3
kevinkr's Avatar
Originally Posted by waverider View Post
The turntable belongs to my mother in-law. <snip> I have the turntable on my workbench. She has called four times in the last 90 minutes.
Doug
You know they say no good deed goes unrewarded...
General information and manuals here: BeoWorld - Everything Bang & Olufsen
MMC5
Before you go too far you had better do some research on the MMC-5 cartridge/stylus issue as it appears to be very difficult and expensive to find a replacement. (No one seems to make replacements except for the very earliest B&O) carts) The stylus apparently is not user replaceable.
MMC4
Edit: I see the OP posted about 7 months ago so all of this is probably a non issue now. Hope it turned out ok.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Beogram 4500 tonearm adjustmentHide this!Advertise here!
VTA Adjustment Mechanism for DIY Tonearm? InSides Analogue Source 8 1st February 2009 03:17 PM
Micro Seiki M505II tonearm height adjustment kffern Analogue Source 3 19th November 2008 01:16 AM
Technics SL-1600mk2 Tonearm Bearing Adjustment philibuster Analogue Source 19 1st October 2007 07:53 PM
Beogram cdx 2 jbator Digital Source 7 14th February 2006 07:29 AM
