| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
So whadya Think? Can this be used with a Vacuum Fitting, all Sealed up, maybe some Spatula Silicon around the Edges and a Pump..Bingo..Disposable RCM Wand??
1 LINT BRUSH - eBay (item 270528646311 end time Mar-10-10 18:18:46 PST) |
#2 |
I used an old crevice tool from a house vac. Cut a slot on one side and wrap it with heavy velvet material from a fabric store. I used the spray on 3M adhesive to attache the material. Also plug the end with something. Works great and cost a couple bucks.
Jeff |
#3 |
Jeff (and sled108)
I use a "Shark" vacuum. A POS as a vacuum, but enough for records (it doesn't create too much vacuum). Even works dry and can handle small amounts of liquid without any problems. The VPI brush is nice, and if ya want to something more deLuxe, the way to go. You could use a DD turntable if you like. I guess you could use a JK flipflop to half the speed, as it seems that most RCMs spin around 17 RPM (at least as far as I can figure out).
stew ☮ -"A sane man in an insane world appears insane." |
| El Cheapo Grande | bigjppop | Tubes / Valves | 15 | 25th September 2011 05:18 AM |
| EL Cheapo Quad amplifier??? | bbuz | Tubes / Valves | 3 | 22nd August 2008 11:23 PM |
| Please help with my el cheapo LINE ARRAY!!! | Klimon | Multi-Way | 8 | 29th January 2006 07:42 AM |
| Ropie's El Cheapo Phonopreamp | Ropie | Analogue Source | 1 | 25th November 2004 11:51 AM |
| Software pre-equalisation of speaker and room = digital magic wand. | Circlotron | Multi-Way | 6 | 15th September 2003 12:50 PM |
| Page generated in 0.07717 seconds (69.74% PHP - 30.26% MySQL) with 10 queries |
