Assistance required to identify replace in Luxman T-240 tuner
Old 9th February 2010, 12:22 PM   #1
hew128 is offline hew128  Singapore
Question Assistance required to identify replace in Luxman T-240 tuner
Need assistance to identify a Sumida part (L101) on the motherboard of a Luxman T-240 tuner. And if anyone knows of a substitue for it.
The item is black rectangle with two hex key nuts for adjustment on the top. Think it needs to be replace on my friends tuner as it did not sound good until I discovered one of the hex nuts seem to be loose (in some manner). When I touched the hex nut with my finger, sound on the tuner either goes silent or sound terrible. Touching it again, sound can be great! Hence as a temporary fix, I managed to glue it into position. Sounds acceptable at the moment but would be preferrable if the Sumida part can be replaced.
Any assistance will be greatly appreciated.
Thanks!
Old 9th February 2010, 01:58 PM   #2
lcsaszar is offline lcsaszar  Hungary
If there are two of them (one for R, one for L channels), that must be a FM multiplex filter. TOKO used to produce such filters (and AFAIK Sumida is TOKO). If there is only one, it could be the FM discriminator. If the ferrite core is not broken, you don't need to replace the whole part. Adjust the loose core for clean sound and maximum audio output. Do not touch the other core. Better alignment can be achived with instruments.
Old 9th February 2010, 02:27 PM   #3
Hi oshhifis,
Afraid is the ferrite core on the FM multiplexer filter as when I put a screwdriver near it - it stucked!
Any ideas on the replacement?
Thanks!
Old 10th February 2010, 06:41 AM   #4
It is the FM detector indeed. No need to replace IMHO. Use a plastic screwdriver, not a metallic one. The SM can be downloaded from here:
Luxman T240 Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
I hope I could help.
Old 10th February 2010, 09:03 AM   #5
Thanks!
Will try to download it later today!
Assistance required to identify replace in Luxman T-240 tunerHide this!Advertise here!
Assistance required in rebuild of a focal crossover soundengine355 Multi-Way 34 1st April 2009 01:05 AM
Hi everyone. Assistance required for DIY Audio beginner! the_chase1 Introductions 4 24th November 2008 10:55 PM
WTB: Luxman T33 Tuner markzb Swap Meet 0 9th May 2005 05:17 PM
The pin identify for replace the clock hatasa Digital Source 8 28th December 2001 04:28 PM
