| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I've tried everything...distilled water, 99% alcohol, Dawn, Sunlight, Windex..Everything. Some of my records still sound crackly despite what a lot of people say about these products.
I'm thinking it could be a static problem...Has anyone ever heard of using Armor All on records? Anything else I could use that would help my situatin here? Thanks |
#2 |
Do a little search here at the forum. You'll find quite some good info on cleaning records.
Personally I use a Okki Nokki cleaning machine and made a cleaning solution like they do at the library of congress Cylinder, Disc and Tape Care in a Nutshell (Preservation, Library of Congress) |
#3 |
Have you used a record cleaning machine?
I'm currently amassing parts to build my own, but otherwise I use the VPI 16.5 we have at work. It's a miracle machine, give the records a good scrub with the vpi juice and then a spin on the cleaner and they're as silent as they'll ever get. (PS I'm pretty sure the VPI stuff is the same as the Congress stuff)
Wherever you go there you are. Last edited by raypalmer; 2nd February 2010 at 06:18 PM. Reason: addition |
#4 | |
#5 |
Air compressor with the sports ball filling attachment a few mm above a spinning record does the trick too.
Takes some time, but does a heckuva job Cheers! |
#6 |
Ok what is Tergitol™ 15-S-7 Surfactant, and where can you get it.
#7 |
Give Dow Chemicals a phone call.
#8 |
Location: Scottish Borders - Kelso; on the famous Tweed River!
Be very careful of using chemicals. They accelerate the migration of the plasticisers used in manufacture. Such migration is a natural process which speeds up in warmer rooms. The result is that the surface becomes more brittle and this can only result in more noise.
The other danger is that some chemicals can loosen the glue which holds the stylus to the cantilever and result in it coming adrift. I cfan unfortunately speak from experience on this risk! No doubt someone who knows the science involved can post more fully on this. Last edited by brianco; 3rd February 2010 at 03:21 PM. |
#9 | |
Tony Ma |
#10 |
Good advice, Brianco.
I use the Tergitol solution and rinse the record twice thoroughly with distilled water. I have done test with an old record. Using the Tergitol solution without rinsing leaves visible stains but I wasn't able to hear any suspicious noises or artifacts. |
| Using large buffer FIFO on SPDIF fed DAC | wa2ise | Digital Source | 8 | 2nd February 2006 03:43 PM |
| fed up with bosoz | cowanrg | Pass Labs | 104 | 19th January 2006 09:57 PM |
| CCS fed shunt regulators | mark_titano | Tubes / Valves | 3 | 30th May 2005 03:14 PM |
| Question about # of bits fed to a DAC | MtBiker | Digital Source | 3 | 30th September 2003 12:53 PM |
| Page generated in 0.09465 seconds (83.54% PHP - 16.46% MySQL) with 10 queries |
