Old 3rd February 2010, 05:02 PM   #11
infinia is offline infinia  United States
infinia's Avatar
If there is that much exasperation something else is going on? How many dirty records Versus perfect ones do you have? Could it be a misalignment or even broken stylus?
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 3rd February 2010, 05:44 PM   #12
soma89 is offline soma89  Canada
I have many records that sound awesome, some that sound ok and some that sound horrible. The ones that sound really bad are all old mono records from the 60's which could be part of the problem.
Old 3rd February 2010, 05:51 PM   #13
trd1587 is offline trd1587  Canada
trd1587's Avatar
Since the tip is often made with a diamond, could it simply grind the spiral. Such a way that it cannot be restored anymore. Also Vinyl is sensible to UV and heat\cold. It Might only be aging? The Same way you move you hand on your aged wife's skin?
My toughts........
Marc
Old 3rd April 2010, 04:07 PM   #14
Originally Posted by Netlist View Post
Good advice, Brianco.
I use the Tergitol solution and rinse the record twice thoroughly with distilled water.
I have done test with an old record. Using the Tergitol solution without rinsing leaves visible stains but I wasn't able to hear any suspicious noises or artifacts.
Does anyone know the correct way to dispose of Tergitol after cleaning records? Can this be dumped down the drain?
Using large buffer FIFO on SPDIF fed DAC wa2ise Digital Source 8 2nd February 2006 03:43 PM
fed up with bosoz cowanrg Pass Labs 104 19th January 2006 09:57 PM
CCS fed shunt regulators mark_titano Tubes / Valves 3 30th May 2005 03:14 PM
Question about # of bits fed to a DAC MtBiker Digital Source 3 30th September 2003 12:53 PM
Page generated in 0.07237 seconds (73.50% PHP - 26.50% MySQL) with 10 queries
