| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Anybody have suggestions for getting more detail and dynamics out of this little circuit? I already replaced all the caps.
It's in my wonderful old, vintage Pioneer SX-727 receiver. I recently ran the turntable I use with it into a good free-standing phono stage and on to a Pioneer line-level input. The difference was night and day. I'm going to update the power supply caps shortly. Thanks for any ideas. |
#2 |
I am in the process of installing an LM4562 based RIAA section in my Pioneer SX-838 -- aren't these great receivers?
I would suggest that you look at the Murata thread I started -- these DC-DC converters are easy to tame with a little choke on the input: When you need +/- 15VDC and have only one pole Here's how I used the National Semi LM4702 to drive some lateral MOSFET's within the carcase of the SC-838L LM4702 meets the Pioneer SX-838 |
#3 | |
Interesting stuff! What new diodes did you put into the power supply? Thanks. |
#4 |
Most likely they were replaced with On-Semi MUR860's. I did replace the filter caps with 39,000uF Panasonics. the original used wire-wrap to the chassis for all the grounds. this had to go. all of the grounds are now brought to one central locus on the power supply.
There is a 32V takeoff on the preamplifier board. One of the Murata dc-dc converters will accomodate this with +/- 15V -- this way you can use a real ground and eliminate coupling capacitors. With the LM4702 the dc offset is only a couple of millivolts. |
#5 |
#6 |
Yupp -- the business side of the power supply is downward facing -- there was enough room to install MUR860's and snubbers.
To mount that filter caps I had to use mounting hardware such that the cap protrudes about 0.75 inch into the bottom. No big deal. |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| Improve this Boonton 1120 Output Stage | jackinnj | Everything Else | 9 | 13th November 2007 07:04 PM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
| Pioneer A400 Phono stage | Smiffy | Solid State | 2 | 6th February 2005 08:50 AM |
| Page generated in 0.09637 seconds (77.32% PHP - 22.68% MySQL) with 11 queries |
