| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I need the schematic diagram from the switch mode power supply. Who can help?
Here the PDF schematic of the preamp itself (please note: first generation Linto, not currently version !!! ) I have created this schematic for the introduce of an interface (to connect an external parallel regulated power supply) some years ago. |
#2 |
Thank you very, I own one Linto & due to a storm the smps has gone, I asked Linn to supply me a new smps & the answer was buy a new unit.
#3 | |
Unfortunately I haven't find out the manufacturer of the SMPS for the Linto. At best you buy a second failured device of your SMPS (e. g. by ebay). Then you can send me both for a cost estimate and repair. Please ask additional Linn in Spain, how expensive is a replacement SMPS for Linto. Last edited by tiefbassuebertr; 27th January 2010 at 05:41 PM. |
#4 |
"Thank you very, I own one Linto & due to a storm the smps has gone, I asked Linn to supply me a new smps & the answer was buy a new unit. "
Thats terrible. Lighting happens. Looks like that's another brand to avoid because of a crappy attitude to after salses service. |
#5 | |
I also noted from Linn always that repair service are well run, because inside only very few "custom made" devices (of course only when there are the circuit diagrams). For the first Linn amplifier device e. g., - the LK-1 most components are still to find, even the Hitachi MCU from the processor PCB. Now we note, that there are already two faulty SMPS devices for the Linto (yours and that one from merlin el mago). After additional find of a second failured pair we have 4 pieces and then I could start to create the schematic (reverse engineering). Unfortunately I haven't such failured power supply, but maybe someone is willing to send me such defective SMPS. After completion of the schematic maybe we have found further 10 units ore more, and I could start troubleshooting. In the attachement the schematic of "Brilliant" SMPS from HDS-Power. I have created it some years ago to carry out the repair service by 12 pieces failured devices. Except the transformer and the very special enclosure (see the embedded version inside of "Kairn" from the attachements) no custom made devices there are in use. The first picture shows the embedded SMPS, from which is the created schematic. The second picture shows an other (older?) "Brilliant"- version from Linn. This schematic I don't have !! By the way - an interesting solution for the voltage select 115VAC/230VAC from SGS-Thomson (ST) also inside; more information (circuit description) easy to find about the appropriate application notes (see datasheets from "ST and "TI"). Last edited by tiefbassuebertr; 29th January 2010 at 10:40 AM. |
#6 |
Thank you for the Brilliant U25W schematic. My Linn Wakonda uses the same PS (as far as I can tell) and died several years ago. Symptoms include a dim power indicator light which slowly dies altogether within 2 or 3 seconds after switching the unit "on". The indicator panel never is illuminated.
On page 3 of your schematic (drawing 21.12.2001), the main faults are listed as R15-R14-R9 of the AVS and R13-R12 of the 9V4 start voltage circuit. Is this where you would start with troubleshooting my problem? Thank you! |
#7 |
@Tiefbass: In the Linto schematics the transistors marked as 4E and 2G (page2) are of different Type NPN/PNP. The ZETEX FMMTA56 and A92 are both PNPs. Could it be that the 2G-marked types are FMMT A06? jauu Calvin |
#8 | |
First you need a second Wakonda device - also with SMPS - with proper function. Then you must disconnect the SMPS in both devices and connect both to each other Wakonda device - you can also test this also with "Karik" and "Kairn", if there is the same SMPS inside. Only now you can observe, whether amplifier or SMPS is faulty. If the mentioned error is clearly comes from the SMPS, then you can check R15-R14-R9 of the AVS and R13-R12 of the 9V4 start voltage circuit as first steps of troubleshooting. Calvin: FMMTA06 = 1G - go to http://www.diodes.com/zetex/_pdfs/3.0/pdf/FMMTA06.pdf 2G could be a read error or misprint from me - but you are right - it cannot be a PNP. The types not critical in generall - the only importamnt thing is the appropriate choice according the idle currents. By the way - the RIAA head amp from LK-1 is only in unimportant details different but basicly the same circuit !!! If you want to clone, use the leaded transistor types from LK-1 (from DIODES formerly ZETEX). Last edited by tiefbassuebertr; 2nd February 2010 at 10:19 PM. |
#9 |
schematic for "LINTO" SMPS still needed
#10 |
Who knows the manufacturer of this SMPS ??
| Digital Audio Cross Selector "D.C.A.S. 7-3" from DIGITRONA - schematic wanted | tiefbassuebertr | Digital Source | 1 | 17th June 2011 07:06 PM |
| Ultimate MC RIAA phono pre for "Blue Oasis" (Win Research Group) schematic? | tiefbassuebertr | Analogue Source | 5 | 19th April 2011 08:36 AM |
| 31 Band Equalizer "the t.eq" "TQ-60" schematic wanted | tiefbassuebertr | Solid State | 2 | 29th March 2010 03:45 PM |
| Schematic wanted for VTL Preamp "Maximal" | tiefbassuebertr | Tubes / Valves | 18 | 28th January 2010 04:34 PM |
| Schematic - B & K MC-101 Sonata (Pro-MC-10) Preamp | dtm1962 | Solid State | 0 | 13th June 2006 07:46 PM |
| Page generated in 0.12311 seconds (82.88% PHP - 17.12% MySQL) with 11 queries |
