Old 12th January 2010, 08:34 PM   #11
Ivey is offline Ivey  United States
Ivey's Avatar
Default Bypass Cap.
At the time of operational testing, it showed that it was not required. In the early days of LP cartridges, some outputs ran high and others low. And the impedance on other were not so good.
But yes, you could bypass it. Yet the 680 ohm and the 47uf/50 does double duty for you in that area.
Check it out please.
I will dia. it for you stand by.
Take Care.
Ivey
Old 12th January 2010, 08:52 PM   #12
sonidos is offline sonidos  United States
sonidos's Avatar
Hello Mr. Ivey! Thanks for the contribution. I apologize if you have answered this, but how clean of a psu do I need for your 2n2222a version? Is this circuit very sensitive to ripple? I certainly would like to try it.
Old 12th January 2010, 09:12 PM   #13
Ivey's Avatar
Default Dia.
Look at this
ivey
Old 12th January 2010, 09:19 PM   #14
sonidos's Avatar
Ahhhh, thank you! I have a LFD Mistral, which uses an 8 legged op amp DIP for gain. This circuit should be interesting and fun!
Old 12th January 2010, 09:47 PM   #15
Ivey's Avatar
Default I have a good PSU for the 2N2222A
Allow me a few minutes to draw it up and I'll post it.
But here the scoop on it.
This circuit is good for low voltage and high current with very low ripple.
You can get everything you need at your local Mall Radio Shack.
I came across this circuit when I was building Class A's. It turned out to be pretty good. No dips when heavy current is called for.
This circuit may be used where high current is required, with a low ripple. The value of C2 smoothness , is about 48,000uf, base on the gain of Q1 and Q2 in their Darlington setting..
Take Care
Ivey
Old 12th January 2010, 10:48 PM   #16
Ivey's Avatar
Default A PSU for 2N2222A
I used this circuit many a time. See if it is useful to you
Take Care
Ivey
Old 12th January 2010, 10:59 PM   #17
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
ivey,
thanks for your contributions.
does you circuit count on q2's base current leakage to bias the zener or is a resistor missing?
mlloyd1
Old 12th January 2010, 11:22 PM   #18
sonidos's Avatar
Thanks again, Ivey. I'm starting out on the ground floor on these things, but is this not a cap multiplier? I had been wanting to try one and now I have a good excuse. It looks like I can find those parts w/o even breaking a sweat. Nice!!!
Old 13th January 2010, 02:38 AM   #19
Ivey's Avatar
Default Mr MLLoyd1
No Sir, the 82k provides base bias for Q2, throught the feedback loop. The 680 ohm resistor, 1k resistor, the 47uf/50 provides reference for the zener.
the zener is used to provide reference to Q2's gain section, because you have two feedback loops to that section. The RIAA and the negative feedback loop of the 82k resistor.
If the reference voltage is lost, the unit could go into oscillation. When current demands are present.
I have played the phono amp without the zener, and it sounds muddy. With it, it is sweet and warm for a ss unit.
Take Care
Ivey
Old 14th January 2010, 11:02 AM   #20
If i understood correctly, i should use the power supply on the picture and that phono stage and that's it? It's writen that power supply output voltage is 35 VDC. But input voltage for phono is 30 VDC. What kind of transformator to use? Secondary winding of transformer should have 24 V probably? How strong transformer to use?
greetings
2N2222A transistor and transisitor history ncdrawl Parts 119 19th February 2010 10:28 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
phono preamp wombil Solid State 5 21st May 2008 11:59 AM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Phono PreAmp JTT Analogue Source 20 15th September 2004 04:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
