Parasound JC3 Phono
Parasound JC3 Phono
Old 13th November 2012, 04:08 AM   #941
ANADIGIT is offline ANADIGIT  Europe
Banned
Yes, I lived here 4 yesrs ago.
John, patent meant you should keep your product designed away from Ebay seller whom need to sell a copy.
Regard
Anadigit
Old 13th November 2012, 04:21 AM   #942
john curl is online now john curl  United States
john curl's Avatar
There is NO patent material in the schematic I published. I gave it to YOU to study, and anyone else, as well. In my opinion, it is a good design, but not a Vendetta or Constellation grade design. They are my best efforts.
"Condemnation without Examination is Prejudice"
Old 13th November 2012, 05:00 AM   #943
Banned
Default Great
Thanks, John
I'll try to do a little bit MOD on your product.
I loved its sound but what I though it was Vendetta, I saw many review refer to Vendetta and there're no talk about their different since this week you've shown your designed.
Looking for JC 2 in the next job :-)
Regard
Anadgit
Old 13th November 2012, 11:22 AM   #944
EDDELARUE is offline EDDELARUE  Brazil
EDDELARUE's Avatar
Send a message via MSN to EDDELARUE Parasound JC3 Phono
Originally Posted by john curl View Post
The only real mod for this design is the IC's used.
ADA-4898 ?
ADA-4899 ?
AD-8099 ?
Only speculation
eD
Old 13th November 2012, 11:56 AM   #945
gk7 is offline gk7
What would a suitable (available) substitute for the 2SK246 Fets be ?
Old 13th November 2012, 12:31 PM   #946
reinhard is offline reinhard
Y means an IDSS from 1,2 to 3,0 mA. Think Fets with IDSS around 2 mA are suitable.
Reinhard
Old 13th November 2012, 02:25 PM   #947
john curl's Avatar
Before any details are argued over, let us come to understand the schematic as a block diagram. It is a 2 stage design with the high frequency EQ between the 1'st and 2'nd gain block. (1600 X .047uF) Then the second gain block equalizes the bass boost that is also necessary. This is essentially the same block diagram as the Vendetta Research, except that the Vendetta uses an OPEN LOOP transconductance amp instead of a high feedback op amp. The additional op amp sections add balanced output and servo control of the DC gain. Almost any low current fet can be used as an output offset, or it can be ignored, if you want. The circuit will work without it.
Old 13th November 2012, 11:51 PM   #948
john curl's Avatar
Any 1A or so, complementary power mosfets will work.
Old 14th November 2012, 12:34 PM   #949
Banned
Default Stereophile
Everyone, Have you ever seen this review & ranking ?
Anadigit
Old 14th November 2012, 09:13 PM   #950
toufu is offline toufu  United States
Anadigit, are you trying to sell a clone version of this or what?
Parasound JC3 PhonoHide this!Advertise here!
parasound HCA-1206 (Tony at Parasound.com) ostie01 Solid State 1 10th July 2012 05:24 AM
Need to change phono gain on Rowland phono module Mikelo Solid State 0 4th October 2009 01:43 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
Phono transformer VS Active phono pre ckwong99 Analogue Source 0 2nd November 2005 04:35 AM
Parasound arnaudcoco Parts 0 24th August 2005 02:29 PM
