Parasound JC3 Phono - Page 51 - diyAudio
Old 23rd April 2011, 07:18 PM   #501
scott wurcer's Avatar
Originally Posted by ThorstenL View Post
And work is the curse of the drinking (and music listening and shagging) class, to which I definitly should be a-counted...
Anyone needs a consultant?
Ciao T
I saw a picture of you and your wife on the web, everyone should be so lucky. You could charge a lot more for that consulting than mere audio.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 23rd April 2011, 10:07 PM   #502
john curl's Avatar
Sorry Bappe, nobody seems to be interested in a BUILDABLE, quality phono front end.
"Condemnation without Examination is Prejudice"
Old 24th April 2011, 12:34 AM   #503
You're not listening. This is about all we are talking about. Using what we can get now.
Old 24th April 2011, 12:45 AM   #504
john curl's Avatar
2SJ74 devices are difficult to get. Yes, there are a few around here. However, WE find them almost impossible to get in quantity, and we would like to avoid them in less critical designs, JUST LIKE THE JC-3. Why do you think that we used IC's? However, there is a 'loophole' that I would like to explore. This is: What about JUST N channel Toshiba or equivalent devices? They are quiet, still available and not too expensive, YET! This could have made the JC-3 even better. That is why I am attempting to discuss topologies like you use in IC design, but in discrete.
Old 24th April 2011, 09:37 AM   #505
Hard to get 2Sj74? Nope, easy. In DIY quantaties.
Here's my take on a "VendettaRevA" in Retin style. SNR is 75 dB rel 500uVrms 20-20kHz unweighted. Good enough, IMO. Gain is 64 dB. I remade the
DCservos a bit and I use OPA627 as DC servo OPamp.
I use Zetex ZVP/ZVN3310 at a failry high idle current instead of the original MOSFETs.
The 2nd stage in the first amp-stage is now made outof BJT:S running at around 20mA.
Old 24th April 2011, 10:05 AM   #506
MiiB is offline MiiB  Denmark
would it harm to take the first servo out.. and instead capacitor couple..in order to get too much varped record filtered out a bit..
Old 24th April 2011, 11:31 AM   #507
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Building stuff is hard work.
Indeed
Old 24th April 2011, 01:26 PM   #508
Good point, John. I have advocated the use of N-channel-only phono input stages all along, for both MC and MM designs. The LSK389 is a good part.
Bob
Old 24th April 2011, 01:34 PM   #509
It is not necessary to take the servo out and put in a coupling capacitor to achieve some LF rolloff to deal with warp. A properly-designed DC servo can be made to provide the desired first-order LF frequency response cut. Just remember that the DC servo is really in the audio path, and should be constructed with audio-grade components. It is part of the whole system. This is especially true when it is being used as a filtering function in the subsonic audio range.
Significantly, you can design the DC servo with an additional pole in its feedback path to achieve a second-order subsonic filter response if desired.
Bob
Old 24th April 2011, 01:40 PM   #510
John,
For a slight shift in direction. In the past I have mentioned when using IC's I prefer to not use the same voltage for both rails. I take it in the JC3 both rails run at the same voltage?
My other new trick is in RC shunt filters. Instead of having the R go to signal common, I find you can use 2R x 2 with one going to each rail. Same filter action different resistor result. Of course it can be "voiced" with an additional wye resistor to signal common.
Now of course everyone knows there is no difference in those changes as long as the resistors sum to the same value, but of course there is a real difference!
ES
parasound HCA-1206 (Tony at Parasound.com) ostie01 Solid State 1 10th July 2012 05:24 AM
Need to change phono gain on Rowland phono module Mikelo Solid State 0 4th October 2009 01:43 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
Phono transformer VS Active phono pre ckwong99 Analogue Source 0 2nd November 2005 04:35 AM
Parasound arnaudcoco Parts 0 24th August 2005 02:29 PM
Copyright 1999-2017 diyAudio
