Parasound JC3 Phono
I should have mentioned that the driven cascode mainly helps the signal-related drain-source capacitance issue in the case where feedback is used in the first stage in a single-ended input design. In the non-feedback design it might help some with common-mode effects.
It is also worth noting that the gate-source capacitance issue, which can be more significant with multiple paralleled JFETs, will be less in a differential input stage that uses feedback, since the feedback effectively bootstraps the sources to follow the signal, reducing the effective gate-source capacitance seen by the cartridge.
Bob
Moving Coil Cartridges - Goldring
These are manufacturer´s specs, and none of them (except for the high output one) is above 12uH. The have specs for DC resistance too.
For the other carts mentioned I could not find manufacturer data so these informations should be seen as "unconfirmed".
Hi Georg,
Thanks for bringing these Goldring specs to our attention. Its nice to see at least one manufacturer specifying inductance. It is significant to note that even the high-output Goldring, with a nominal output of 2.5mV, has inductance of only 200uH and resistance of 77 ohms.
I agree that unless we can gain higher confidence in those other cartridges that were cited to have L in the range of 50 uH, we can probably not worry too much for most MC cartridges frequency response being unduly influenced even when driving a virtual ground, as the pole of DCR and L will be at a fairly high frequency (as an example, 5 ohms and 10 uH will be at about 80 kHz).
Bob
diyAudio Chief Moderator
Joined 2002
Brings a chance to remind why the ''lost pole'' compensation could be much controversial with clashing feedback from different users and systems. It may mess with unpredictable supersonic curve of cart and pre combinations in the larger pool of installations.
Bappe, there is only one potential noise contributor that I see, and that is the use of 47 ohms as the current source Gm reducing component. I would go for 100 ohms or more. You might look at the 'improvement' on Spice, regarding noise contribution of an active load. I avoid this, myself, by just using a resistor, rather than a current source, but it does complicate the power supply.
Hi bappe,
I like this design. I have been a fan of N-channel JFET differential input stages, even though they do not produce as low a noise level as single-ended designs. Even in an MC design, four paralleled LSK389 dual JFETs will yield 1 nV/rt Hz or better noise performance. BTW, my simulations show that 1 nV/rt Hz will achieve a 77 dB SNR RIAA equalized and A-weighted with respect to a 400uV nominal cartridge input voltage. For reference, I believe that the excellent JC-3 is rated at 75 dB SNR under the same conditions.
The differential input stage lends itself nicely to running with no NFB or with NFB. No NFB in the input stage is OK in this application because of the small input levels involved and the use of the differential input stage to keep distortion down. Also, the no-NFB stage makes it easy to go balanced at the input if desired.
Going no NFB does involve some gain and channel balance uncertainty due to the JFET device-to-device characteristics unless they are chosen carefully and matched, but this is reasonable in a high-performance design.
There is still the option of NFB or no NFB in the output stage, given that the levels will be higher. This may be more of an issue for the MM stage than the MC stage.
It looks like you are running the input JFETs a bit on the high side in regard to Vds; this could cause you to incur a noise penalty. If you wish to keep the output portion having as much voltage swing capability, you might consider adding a conventional cascode between the input drains and the folded cascodes.
If you are concerned about JFET input capacitance, you can use a driven cascode.
Bob
You are of course correct reg noise performance and other comments. I did want to keep the component count down so i skipped the first cascode and you are right, the voltage should be taken down on the input devices. I do not consider the capacitance to be much of an issue though and i do think it would perform quite well open loop.
BR,
Anders
BR,
Anders
Hi bappe,
I'm not sure of the numbers, but the capacitance issue is likely to be more important for an MM application, given the much higher cartridge impedance of an MM cartridge. This will not be as bad if paralled devices are not used to get the noise unnecessarily low for the MM situation, although the use of even large single JFETs should be perhaps viewed with caution, especially in a no NFB MM input stage. We really don't want any MM cartridge interactions with the input stage.
BTW, this is why MM/MC preamps that use the same first stage for both types of cartridges are not a good idea. The optimum input stage for these two applications is quite different. A stage that has low enough noise for the MC application will tend to be quite sub-optimal for the MM application.
Bob
Hi bappe,
Bob
Oh so true! This one is sort of universal but probably best siuted for highish output mc's. If going for a low mc to mm it would take parallell devices and maybe a driven cascode.
//A
Bappe, YOUR design could be used effectively with BOTH MC or MM cartridges. However, it is the current source loading that is the potential problem.
I would hope that you can look at the active loads as potential noise amplifiers, injecting their noise into the second stage transistor bases. Kind of like competing signal sources.
I solved this problem, decades ago, BUT my solution would 'compromise' your circuitry with more parts, caps especially. Let us find a QUIET LED replacement with 3.3-6V drop. Hopefully 2 terminal, and low Z.
Hi Bob,
how about this Erno Borbely phono amplifier for both MM and MC?
Hi bappe,
Bob
No, too much input capacitance from numerous paralleled JFETs. If you get the noise low enough for MC use, you have probably ended up with too much JFET input capacitance for MM use. Bear in mind, this capacitance is nonlinear.
Bob
Yes, you exceed the recommended C with the FET's alone let alone the cable. The non-linearity at these levels is a problem overstated IMNSHO.:D
