I made good experiences with this one :
http://cds.linear.com/docs/Datasheet/1468fb.pdf
I have not found the book yet about surround sound from two channels but this guys claim to be able to do it with ONE channel only.
OK, Scott, with processing.
http://www.swissaudec.com/pdf/FAQ_Home.pdf
Gotta have that "professional" recording studio in your IPHONE. As I said before Bob Adams showed me a circuit with a cheap dual op-amp and a pot that moved the image around your head and back again.
EDIT- Read more, a real Swiss Army Knife product, even improves doppler ultrasound. No "world wide" patents found yet.
"The MAX9632 is a low-noise, precision, wide-band operational amplifier that can operate in a very wide +4.5V to +36V supply voltage range. The IC operates in dual (±18V) or single-supply mode (36V)."
No simplified Schematic in the data sheet
Rgds
James
Rgds
James
No, as I mentioned this stuff doesn't do much for me.
found it http://www.faqs.org/patents/app/20110075850
EDIT - Tech question, is there an escape sequence so real text does not turn into a smilie?
Their explanation of how it works seems to boil down to:I have not found the book yet about surround sound from two channels but this guys claim to be able to do it with ONE channel only.
a) Stereo can be reconstructed from sum and difference signals (duh!)
b) Every year electronic devices get smaller
c) Most FM broadcasts are still mono
d) Sometimes bad weather adversely affects TV reception
e) Something about a patent
Don't think I'll invest just yet
CMRR @DC (dB) 135
PSRR @DC (dB) 140
Input IBIAS (nA) 180
Unity Gain BW (MHz) 55
Slew Rate (V/µs) 30
in (pA/√Hz) 3.75
MAX9632.pdf
PSRR @DC (dB) 140
Slew Rate (V/µs) 30
in (pA/√Hz) 3.75
MAX9632.pdf
- Analogue Source
- Parasound JC3 Phono
