Old 8th January 2010, 05:50 PM   #1
tiefbassuebertr's Avatar
Default Better Connectors instead this ordinary DC Power Jack/Plug Connections ?
A wide range of phono RIAA headamps (phono preamplifier), that have outsourced main transformer for the power supply, used dc plugs/sockets like this showed in the attachement. Also some very expensive headamp devices (horrible for me).
I want to have better connectors instead this ordinary versions - but approximately in the same sizes. What is recommended as a better alternative?
Thank you for your comments
Old 9th January 2010, 02:14 AM   #2
Leolo is offline Leolo  Canada
Leolo's Avatar
You mean the barrel connector? What don't you like about it?
Old 26th January 2010, 03:57 AM   #3
merlin2069er's Avatar
Send a message via MSN to merlin2069er
I hate them as well. I've got 2 battery powered monica dacs I've built, and they both have 2.1mm power jacks.
The power plug doesn't fit snug, and I've always got to jiggle it. There's got to be a better way to secure power from a battery (or anything for that matter).
Old 26th January 2010, 04:09 AM   #4
sangram is offline sangram  India
These ones? they come fitted with some hard disk cases, and can do a couple of amps on each pin. Fit is reasonably secure, far better than that tiny one which was meant for portable players...
Old 26th January 2010, 09:21 AM   #5
Means the therm "barrel connector" a specific connector or is it only a general designation for a a particular connector species? I don't know this exactly, but if I look by "google", also the F connector for satellite tv and some BNC/FMA connectors are called "barrel connector"
I certainly thought the plugs and jacks for DC connections as showed by the second attachement (PDF) from post #1. This are bad after short time of use because there are undefined transition resistance; for normal low-cost applications irrelevant, but not for high quality RIAA head amps !!!
Sangram: a good solution if the dimensions (sizes) allow it.
Old 26th January 2010, 11:52 AM   #6
It's a tiny little thing, about the size of an S-video connector. AFAIK the female come only in panel-mount version unlike S-video and the pins are about 3x thicker, but for the life of me I don't know what it is called.
Old 26th January 2010, 12:21 PM   #7
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
There are Mini-DINs, mini XLRs, a japanese type often called "microphone" connector used on lots of HF/VHF radio gear, there's LEMOs ( expensive ), but for size it's hard to beat the cheapo's.
Mini XLRs would be my best bet, but I'm assuming your box are somewhat thicker than 10 mm, so what's the rush for extra-extra small?
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 26th January 2010, 03:30 PM   #8
Ok, I figured out what someone was using... Just took a bit of goggling around.
Locking plugs and jacks from conxall.
Circular | Digi-Key
Old 26th January 2010, 04:07 PM   #9
Circular | Digi-Key
Thanks for this advive. Good solution. But not in all cases small enough.
http://www.conxall.com/Catalogs/newcatpages/page6.pdf
CONN SOCKET PANEL MNT MICRO 2PIN - 17282-2SG-300
Dimensions: Inches/(mm) - I guess.
Old 26th January 2010, 04:29 PM   #10
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
I would go for mini XLR.
One of the best connectors for Power........
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
DC connectors ho-humm Power Supplies 0 2nd January 2009 03:33 AM
DC power connectors? space-cake Parts 1 30th November 2006 04:43 AM
dc power jack for wah shell? space-cake Instruments and Amps 1 13th October 2006 05:06 AM
RCA Jack/Plug Selection/Switches Pre-amp & 3875 Premium kit Destroyer OS. Chip Amps 15 22nd August 2006 06:43 PM
DC-DC Power converter for Class T amp power supply? rtalk Class D 2 7th December 2004 04:02 AM
Page generated in 0.10753 seconds (78.69% PHP - 21.31% MySQL) with 11 queries
