MC Step-up Xfmr and SNR
Old 9th January 2010, 04:18 PM   #11
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
If i tell you whats on some of my records from the time when i was young you will be shocked.
Old 9th January 2010, 04:22 PM   #12
On Hiatus
SY's Avatar
Doubt that seriously.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 11th January 2010, 04:57 AM   #13
analog_guy is offline analog_guy  United States
Default Cartridge SNR
Unfortunately there's more than white noise at the output. Keeping the hum below the same limits is, from a practical perspective, very unlikely. 200uV hum at the output means an equivalent (in your case) of 1.6nV hum at the input. I doubt any cartridge, arm wiring and cable can go that low in hum capturing. [QUOTE]
This afternoon I tested up a phono amp circuit that I posted on another thread, and I certainly agree with your comments about hum, etc. I am not sure, however, if they contradict the conclusions I described earlier. Whether one uses a high gain phono amp or a lower gain amp with a transformer, the source noise from cartridge and associated wiring will be the same. The amplifier stage, depending on its gain and 1st stage noise floor, will add differing amounts of noise which further degrades the SNR. Perhaps you are arguing that other sources of noise (hum, for example) will swamp cartridge thermal noise. If so, the case for using a stepup transformer may be less compelling.
JCM
Old 13th January 2010, 04:30 AM   #14
syn08 is offline syn08  Canada
That's exactly what I'm saying. And that targeting 10dB as audibility threshold is an overkill.
BTW, transformers are about the worst devices when it comes to hum capturing.
MC Step-up Xfmr and SNRHide this!Advertise here!
MC Step-up transformers mantisory Analogue Source 62 1st March 2015 04:53 PM
nuvistor MC step up reinhard Tubes / Valves 66 14th February 2014 01:27 PM
Mains toroid as MC step up? bigwill Analog Line Level 8 7th October 2008 08:18 PM
FS: VSPS phono preamp & tamura MC step up transformers. rjm Swap Meet 0 25th August 2005 05:42 AM
Penultimate Zen SNR? amo Pass Labs 6 15th July 2003 07:21 PM
