DIY parallel tracker air arm - another one - Page 4 - diyAudio
Old 28th April 2013, 12:57 PM   #31
Geosto is offline Geosto  Netherlands
Hi tnargs.
There is no minimum length bud when the tone arm is getting to short some of your warped albums become garbage.
The height of the warped album is determined, the length of the arm.
Also the used cartridge is a factor in this.
Some are more sensitive.
In my case I will not go shorter than 8 cm.
Old 28th April 2013, 01:12 PM   #32
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
I prefer never to use warped records, but I agree that a shorter arm can have it's pitfalls... think what it can do to VTA when playing different weight/thickness vinyl.
RC
Old 28th April 2013, 01:18 PM   #33
Exactly right.
Old 28th April 2013, 07:30 PM   #34
Moko is offline Moko  United Kingdom
Here's an image that shows the problem of a very short arm
These photos were taken from the LencoHeaven site
Old 28th April 2013, 08:03 PM   #35
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Tnargs
What you need is a vacuum platter or perimeter platter ring clamp such as VPI sells if you want these issues solved in one fell swoop.
Woofer pumping and VTA anamolies solved
David
Old 28th April 2013, 10:35 PM   #36
tnargs is offline tnargs  Australia
Thanks everyone. 8 cm is only about one third of the length of a normal arm, that is certainly quite short! If that is acceptable from the geometric point of view, I might give it a go.
Old 30th May 2013, 01:10 AM   #37
bullpeters's Avatar
Default terminator question
I am wondering what the life span of the "holes in tape" type slide would be. Has any one a technique to drill the holes? Bit concerned that if i glue it up, i can get back in to replace tape.
Also, can i use my shop compressor with a tank upstairs? Not worried about noise but wondering about the small amount of oil in the air.
Kind regards,
DIY Air bearing tangent tone arm neil_kaye Analogue Source 160 12th October 2013 03:20 AM
YAABA - yet another air bearing arm woodturner-fran Analogue Source 1 9th March 2009 11:24 PM
Ladegaard Arm Air Requirements ? valveitude Analogue Source 10 1st February 2007 08:06 AM
MG-1 AIR BEARING Tangential Arm audio-kraut Analogue Source 7 24th November 2004 07:55 PM
Shielding for diy arm wiring when DIY arm itselve cannot not provide it? hybris Analogue Source 12 31st October 2003 11:20 AM
Copyright 1999-2017 diyAudio
