DIY parallel tracker air arm - another one
Old 18th June 2010, 03:05 PM   #21
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
So you are using coils...!
I am using a jfet as primary load so I guess I should use at least 10x internal cart impedance (L=17ohm for the AT 33PTG).
This cart is similar in specs to a Denon 103R and these sing beautifully with 150r.... I will go very near that.
Thanks for the imput.
Ricardo
Old 18th June 2010, 06:21 PM   #22
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
No, Piccolo is fet based.
Yes, very sweet through transformers, a friend has CineMag 3440's.
Jeff
Old 18th June 2010, 09:57 PM   #23
nhinstruments
RCruz's Avatar
Piccolo seems to be only a stepup amp without riaa equalization.... Am I right ?
In that case, what where your impressions when using the 150r loading ?
Does timbre get lost ? Did you not get a wider soundstage ?
Maybe Hagerman Piccolo uses his special upper 3.18us (50kHz) corner in its transfer function built in.... this produces a boost in the high frequencies needed to cope with lathe cutting head cut off at the same freq.
If so, that explains why you need to cut high freq output by heavy loading your cart
Old 18th June 2010, 10:43 PM   #24
vinylkid58's Avatar
Yes.
My Piccolo has stock resistor settings, 47,100,220,470,1k,47k. PTG33 sounds fine at 100R.
Transformer loading sounds more natural, with better detail. Piccolo has a very good soundstage thou.
Not sure. Piccolo is very neutral at high frequencies, compared to transformers. If anything, transformers give better high frequency definition.
Jeff
Old 19th June 2010, 10:17 AM   #25
nhinstruments
RCruz's Avatar
After some reading I understand my question about the upper 50khz corner can not be applied to the Piccolo. (After all it does not have riaa eq built in )
So the AT33PTG sounds ok with 100r.... did you try 220r also ?
PS: I know I am a little off topic here so this will be my last post but I really need your input.
Ricardo
Old 19th June 2010, 04:25 PM   #26
vinylkid58's Avatar
I'll try it at 220 later today and get back to you.
Jeff
Old 22nd June 2010, 06:10 AM   #27
vinylkid58's Avatar
I've been listening to music with my Piccolo set at 220R for a couple days now, and I'm really enjoying the presentation. I've got my big amp back up and running, so really don't have too much to complain about. I think I'll leave the Piccolo set at 220R for a while before going back to 47R to see if I'm missing anything.
Jeff
Old 22nd June 2010, 09:20 AM   #28
nhinstruments
RCruz's Avatar
Thank you Jeff
I really apreciate your input.
Ricardo
Old 26th April 2013, 05:34 AM   #29
tnargs is offline tnargs  Australia
Originally Posted by Geosto View Post
I use a carbon fiber wand also bud the head shell comes from an old AKAI turntable.
If you are making a new wand you may try this to.
Because of the weight from the tonearm wires the pressure on the tip of the needle was not stable.
Hi, I am thinking of trying something similar, but (looking at the above photo) I have a question.
Is there a minimum distance from the stylus contact point to the vertical bearing? The above arm is very short. I would think at some point the VTA starts to vary with record imperfections (undulations) and it affects performance?
Old 27th April 2013, 11:52 PM   #30
P.S my question above is a general question, not just about the arm in the photo.
Is there a minimum tonearm length, below which the angular change (when tracking warped LPs) becomes a geometric issue?
DIY parallel tracker air arm - another oneHide this!Advertise here!
DIY Air bearing tangent tone arm neil_kaye Analogue Source 160 12th October 2013 03:20 AM
YAABA - yet another air bearing arm woodturner-fran Analogue Source 1 9th March 2009 11:24 PM
Ladegaard Arm Air Requirements ? valveitude Analogue Source 10 1st February 2007 08:06 AM
MG-1 AIR BEARING Tangential Arm audio-kraut Analogue Source 7 24th November 2004 07:55 PM
Shielding for diy arm wiring when DIY arm itselve cannot not provide it? hybris Analogue Source 12 31st October 2003 11:20 AM
