DIY parallel tracker air arm - another one
Old 28th December 2009, 08:05 PM   #11
Speedysteve7 is offline Speedysteve7  United Kingdom
Speedysteve7's Avatar
Good point about the headshell mass George.
Newer Terminators have 3 SS grub screws to pop in to mass it up for lower compliance carts.
On the trad arm I needed to go from ~8g Technics headshell on the AT 33 PTG to 14g (Sumiko + 3g) for the Spu with suitable extra counter weight.
That gives me some reference point I guess. I could make the SPU Royal N spacer (need for using trad non SPU headshells) out of Brass - ah hold on I have some gunmetal in the workshop from help a chap out cutting a gunmetal armboard for his SP-10 - that would be perfect. If that is too much I could always make some gunmetal grubs ala Terminator.
Not had any pressure probs. The pump is pretty hearty. I use a 5l smoothing tank (petrol can) - the silencer idea is interesting. Can't say the very slick hiss annoys me though.
Old 16th June 2010, 10:29 PM   #12
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hi Speedysteve7
What is the load you are using with the AT 33 PTG.
I plan to buy one but can not get any info about load.
Ricardo
Old 17th June 2010, 08:54 AM   #13
I was using 1.8g. From memory the range is 1.6 - 2.0g with recommended 1.8g. Someone on Art of sound like 1.85g so around there anyway.
Old 17th June 2010, 09:10 AM   #14
nhinstruments
RCruz's Avatar
Thank you.... I will try that VTF.
But do you know the resistive load of the cart in the phono preamp ?
Ricardo
Old 17th June 2010, 09:20 AM   #15
I used a Dynavector P75 and some use it on the Direct Current or Phono amp setting which is 0.
I found I liked it best on 30 or 40ohms - so pretty low settings work well with this cart.
Old 17th June 2010, 09:23 AM   #16
nhinstruments
RCruz's Avatar
Thank you
Did you ever try 150 ohm ?
Old 17th June 2010, 03:26 PM   #17
I have a feeling the P75 went, 0, 30, 100, 470 or something similar.
I have found in playing around with this the higher the set resistance the more treble / slightly less bass you get.
Old 17th June 2010, 03:55 PM   #18
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
I like mine loaded at 47 ohms the best. I've tried 100 and 150.
Jeff
Old 17th June 2010, 06:36 PM   #19
nhinstruments
RCruz's Avatar
Thank you so much..... It seems there a consensus regarding loading this cart with low r values. This should reduce high freq response....Should it mean that the cart sounds "light" regarding other carts ?
What type of phono preamp are you using Jeff ?
Old 17th June 2010, 10:10 PM   #20
vinylkid58's Avatar
I believe loading the PTG down helps tame the raising treble slightly. So yes, it could sound a little "light" in some systems.
I'm using a Hagerman Piccolo for step-up into a Pass Pearl.
Jeff
DIY parallel tracker air arm - another oneHide this!Advertise here!
DIY Air bearing tangent tone arm neil_kaye Analogue Source 160 12th October 2013 03:20 AM
YAABA - yet another air bearing arm woodturner-fran Analogue Source 1 9th March 2009 11:24 PM
Ladegaard Arm Air Requirements ? valveitude Analogue Source 10 1st February 2007 08:06 AM
MG-1 AIR BEARING Tangential Arm audio-kraut Analogue Source 7 24th November 2004 07:55 PM
Shielding for diy arm wiring when DIY arm itselve cannot not provide it? hybris Analogue Source 12 31st October 2003 11:20 AM
