Old 14th December 2009, 05:02 PM   #1
leadbelly's Avatar
Default What DIY preamp for high output type MC cart?
I don't follow this forum often, and "MC" can't be searched on, so I was hoping for some help.
I just ordered a high output type MC cartridge, the type which can work with an MM preamp.
My question is related to what is the recommended or optimized type of phono preamp with this kind of cartridge? In other words, would an MC type preamp still be best because of low noise or input impedance? Would an MM type preamp be best? Or would some kind of DIY effort, say taking an MC design and cutting gain, be best?
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 14th December 2009, 06:07 PM   #2
MRupp is offline MRupp  Germany
MRupp's Avatar
Wayne Colburn's "Pearl Phono Stage" would be a suitable and pretty good preamp, article should still be on passdiy.com. The Alephono MM stage may be even slightly better, though more complex.
Or: Any of a number of tube phone preamps, including maybe a FVP5 set to lower gain, the D3A phono preamp by Andrea Ciuffola, etc..
My candidates, in no particular order ...
Martin Rupp
Old 15th December 2009, 08:58 PM   #3
MRupp's Avatar
Default Pearl Phono Two
P.S. Just stumbled across this thread: Pearl Two
Martin Rupp
Old 15th December 2009, 10:10 PM   #4
R.I.P.
Leadbelly,
You need a preamp that won't overload on the hi output of your cart - so a pure MC pre will have too much gain and almost certainly be moving into overload, if not there most of the time.
47k would be the correct loading.
I'd (naturally) suggest a tube preamp - there are lots of choices, but make sure you dump any MC step-up traffo - simply not needed.
Regards, Allen
High DC offset voltage at preamp output mmerig Solid State 18 23rd May 2008 07:44 AM
Tuning 604 Project - High Q and High Output Impedance? Seadweller Multi-Way 20 18th February 2008 07:49 PM
best type cap for preamp PSU cbutterworth Tubes / Valves 4 10th November 2006 02:51 PM
Garrard 60 MKII, Phono cart, preamp??? blumenco Analogue Source 1 14th May 2006 03:56 AM
Matching a preamp to high output impedance source ainami Tubes / Valves 5 29th November 2004 04:02 PM
Page generated in 0.10296 seconds (67.54% PHP - 32.46% MySQL) with 10 queries
