Old 11th December 2009, 10:22 AM   #1
fasterbyelan's Avatar
Default Rega Arm Drawing and Position Details Required
I'm in the process of designing a turntable that will use a Rega tone arm (RB250). Does anyone have a CAD drawing they could send me of such an arm - Auto Cad 2000 or .dxf format preferably.
Also I know the distance from the spindle to the centre of the arm 's mount is 222mm but what is the ideal angular position? Visual it appears to be 45 degrees clockwise from the top (ie rear) but is this correct?
Thanks for any help given,
Karl
Old 19th December 2009, 06:23 PM   #2
Send a message via MSN to sq225917
Karl it makes no difference where the arm sits, 222mm is 222mm regardless, you just locate it according to how wide/square/rectangular you want to make the plinth.
you'll find a full set of measurements on vinyl engine, or at least the arm length, the counterweight stub is about 30mm long and exits from a boss roughly 12mm from the bearing centre.
hoping to pick up some things.
Old 19th December 2009, 07:36 PM   #3
merlin el mago's Avatar
ArcProtractor for Rega RB-250, "WARNING" First of all, you must be absolutely sure to have the same mounting distance on your turntable than on the ArcProtractor.
MAXIMUM error on this dimension must be within +/-0.5mm. Otherwise, it is useless trying to align.
Rega vs Baerwald
Old 20th December 2009, 09:10 AM   #4
Calvin is offline Calvin  Germany
Calvin's Avatar
I´m doing the same as Karl at the moment, but with an Rega300B.
So if anyony has a CAD drawing or at least a good pic I could import to CorelDraw I´d be happy to receive a mail.
Calvin
Old 20th December 2009, 10:06 AM   #5
Calvin
The Rega ArcProtractor is to use in all Rega Tonearms from RB-250 till RB-1000, please send me a pm with your e-mail will receive both ArcProtractors in zip format.
Merlin El Mago
Old 20th December 2009, 10:42 AM   #6
EUVL is offline EUVL  Europe
Would also appreciate a copy. Just sent PM.
Thx,
Patrick
Old 20th December 2009, 11:03 AM   #7
Usefull pictures to check the axis in tonearms:
With photo-shop programm can do this:
Merlin El Mago
Old 20th December 2009, 05:57 PM   #8
Calvin
Link with all ArcProtractors & setup: http://www.ls35a.com/
Merlin El Mago
Old 20th December 2009, 06:00 PM   #9
Thx,
Patrick
Sent.
Enjoy,
Merlin El Mago
Old 20th December 2009, 07:34 PM   #10
frugal-phile(tm)
planet10's Avatar
Originally Posted by merlin el mago View Post
Link with all ArcProtractors & setup: The Unofficial LS3/5a Support Site
Merlin,
Lots of LS3/5A info there, but i'm having trouble finding a link ti the protractors?
(does remind me i have to continue pursuing a crossover for a friends bastardized LS3/5A)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
25-position switched attenuator using a pair of 5-position switches? ray_moth Tubes / Valves 1 4th May 2008 08:02 AM
THX requirements (details required)?? mike.e Subwoofers 6 9th July 2006 12:30 AM
My first GC PCB drawing... flying Chip Amps 8 14th January 2005 06:24 AM
Drawing PCB's... eeka chu Digital Source 4 7th June 2004 07:13 AM
CAD Drawing Doug Everything Else 8 8th October 2003 02:52 PM
Page generated in 0.12751 seconds (72.07% PHP - 27.93% MySQL) with 11 queries
