Lid Hinges for Linn (LP-12) Thorens and Sony Turntables - repair?? orig. brand wanted
Old 9th September 2011, 03:32 PM   #21
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by harwoodspark View Post
There's no name on them or any logo and they fit straight onto my Linn with no modification just like the standard Linn hinge. I can't remember which model of NAD turntable I took them off but I'll try and find out.
The hinges in the last picture you show seems to be the right ones.
Interesting hints. I assume, the manufacturer of both hinge versions must actually be the same. Perhaps you call NAD and ask there (for calling by telephone my english is too bad). Linn ltd. will not tell us this name, because the LP-12 is still in currently production and not obsolete.
Thank you very much for your efforts.
Old 9th September 2011, 06:40 PM   #22
harwoodspark is offline harwoodspark  England
NAD 5120. There's three or four for sale on ebay at the moment.
Old 9th September 2011, 08:31 PM   #23
Yes; one belt, two service manuals, one review and only one offer about completly NAD 5120 turntable device
(ebay item No 110734151126).
Old 12th December 2011, 06:43 PM   #24
Brand name for Linn's 2-F-037-H still want to know.
This part isn't custom made, because several other manufacturers like Thorens use this part.
Old 4th April 2012, 09:45 PM   #25
Who know the genuine brand name of Linn's lid hinges and that one of NAD's 5120?
Old 21st December 2012, 09:54 PM   #26
GeorgK is offline GeorgK  Austria
I "repaired" mine a few years ago. Guess this will laster longer than originally.
Note that the spring has cracked off the entire backside. In fact I made the two holes using the nail itself as a drill. So it fits perfectly with no tendency to slip out. And no way the spring will ever work through the nail as it did with the plastic.
Old 25th December 2012, 06:50 AM   #27
SCompRacer is online now SCompRacer  United States
Nice repair GeorgK. Back in 2007 I repaired a pair of Linn hinges. I had some used, dull 3/32" drill bits I cut the shanks (the smooth part) off of. I had some old black 3.5" floppy disks I cut up and glued to the hinge to cover the broken area.
Linn Sondek Dust Cover Hinge Repair
Old 29th December 2012, 08:13 PM   #28
ok, looks better than my nails
Old 1st June 2013, 04:10 PM   #29
chriskauffman is offline chriskauffman
Default Simple Fix
My Sony turntable (PS-LX3) has the same hinges. I discovered a fairly simple fix for you do-it-yourselfers. Drill a hole on each side of the plastic portion just above the pin and insert an additional pin that retains the spring.
Photos at Sony Hinge Fix - a set on Flickr
(Ignore the hole I drilled in the center of the hinge, that was a fix that was unsuccessful)
There is more information on the problem at the following URLs:
Those bl**dy Hinges!
Old 28th August 2013, 05:34 PM   #30
still no informations concerning the manufacturer?
Lid Hinges for Linn (LP-12) Thorens and Sony Turntables - repair?? orig. brand wantedHide this!Advertise here!
Sell or Swap Thorens TD-165 & Kenwood KD500 turntables (B.C.) (and other stuff) dangus Swap Meet 11 22nd October 2007 05:40 AM
Linn and Thorens Mikewong Analogue Source 4 29th December 2005 01:51 PM
Linn Basik plus or Thorens 150 stock? phimor Analogue Source 2 12th October 2005 03:15 PM
Thorens TD150 and Linn springs Zombie Analogue Source 4 16th July 2004 10:32 AM
Copyright ©1999-2017 diyAudio
