Old 2nd December 2009, 05:40 PM   #1
Default Another Discrete BJT MC Preamp Design
Here is my latest design to throw into the ring. It is a 3-stage discrete MC preamp utilizing THAT304 matched PNP-NPN quad as input devices. The remainder of the circuit consists of a cascode VAS stage driving a 4-transistor output stage similar to that used in the OPA627 opamp. It simulates to the same En advertised by THAT Corp: 0.7-0.8 nV/sqrt(Hz). Distortion is in the -120 dB range. There are still a few tweaks to be done (like optimizing input stage resistances to minimize En). I have just about completed PCB layout and should be building the prototype by year's end.
JCM
Old 2nd December 2009, 08:48 PM   #2
Joachim Gerhard's Avatar
when i open your document i can not see the circuit values very well but i like what i see.
should develop into an interesting project. i ordered samples of the THAT304 but never got them, so i am very interested what you experience.
Old 2nd December 2009, 09:25 PM   #3
Default Difficulty Reading component Values
Joachim,
The file is a 2003 SP3 Microsoft Word document. When you open it in Word, go to the toolbar and increase the magnification to approx 150% (it is expressed as a percentage). That should fix the problem.
Jeff
JCM
Old 3rd December 2009, 06:37 AM   #4
i did that but still i could not read the values. the resolution is not high enough on my mac.
Old 3rd December 2009, 06:43 AM   #5
i opened it under windows xp and now it works fine. so mac users may have problems.
Old 4th December 2009, 11:40 AM   #6
tiefbassuebertr's Avatar
same circuit transfer to PDF
Old 5th December 2009, 05:41 AM   #7
Exclamation Correction to BJT MC Preamp Schematic
I noticed the V+ and V- pin numbers on the IC2 symbody are transposed. V+ should connect to pin 7, and V- to pin 4.
JCM
Old 5th December 2009, 05:44 AM   #8
Default .pdf Conversion
Thanks for converting the image to a .pdf format. I don't have an Acrobat converter.
JCM
Old 5th December 2009, 05:51 AM   #9
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
CutePDF - Create PDF for free, Free PDF Utilities, Save PDF Forms, Edit PDF easily.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 23rd December 2009, 05:00 AM   #10
Default Chassis for Above Described Preamp
After a few days in the shop the chassis for the preamp is nearly complete. Lacking access to sheet metal bending tools I elected to use thick material for the front and side panels and then tap/thread to attach the other panels. I could not find knobs to my liking so I machened the ones in the photo. (It helps to have a vertical mill, a drill press and a lathe). Once all the electronics has been installed and everything tested I'll disassemble the panels and send them to an anodizing shop
JCM
Where can I get a pcb for a discrete GC preamp? raypalmer Chip Amps 2 27th January 2009 10:45 AM
Wanted: 12V Discrete Preamp Design TheSeekerr Solid State 6 11th January 2008 06:20 AM
Will this design work for a basic Discrete Guitar Preamp?? Minion Instruments and Amps 11 18th September 2007 03:24 PM
which discrete preamp ? sopapo Solid State 12 13th January 2006 08:11 PM
DIY preamp design - gain topology, IC vs. discrete, OPA627 vs. Zen... ? dorkus Pass Labs 18 10th July 2001 05:26 AM
Page generated in 0.12127 seconds (67.15% PHP - 32.85% MySQL) with 11 queries
