| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
All phono cartridges have only 2 pins, why there are some expensive phono preamp has a balance input?
#2 |
Eeh, because you don't need three pins for balanced operation.
Looks like Sponge Bob has killed another thread. |
#3 |
beeing a coil, the pickup is a floating balanced source. So its quite intuitive to use a balanced input stage, don´t You think? jauu Calvin |
#4 |
real balanced is when the cardridge had 6 pins. one in the midlle of two coils per side.you are refering to pseudo balanced that works in praxis very well to supress common mode signals like hum and radiation. i never needed an earth cabel for my balanced design. it is very imun to outside influences although it has a theoretican noise disadvantage (johnson noise) of 3dB compared to an unbalanced phonostage of half complexity.
#5 |
do not look further than that at this pdf of an "obsolete" part. it shows what i mean but
that wisdom has all but disappeared. http://www.diyfactory.com/data/SSM2017.pdf |
#7 |
The transistor "data amplifier" or instrumentation amplifier was described as early as 1968 (proably earlier). The noise penalty will depend on the real part of the source impedance. For say a 400 Ohm DCR coil it would be easy to make a differential amp with a dB or less penalty. Even easier for a MM input.
A problem lies with partitioning gain and the RIAA time constants. So for phono stages there might be a conflict. For MC, where a fixed differential first gain stage might make more sense you have the noise issue. EDIT - I noticed one of our add banner folks "Seventh Circle Audio" has some good schematics that cover current IC's and discretes in differential preamps.
2012, our time is running out. Last edited by scott wurcer; 30th November 2009 at 11:18 AM. |
#8 |
is the third pin really needed for balanced operation?
regards Andrew T. |
#9 |
per anders, there is a missunderstanding. i did not put forward my apreciation of that chip but found the definition of several types of ballanced (they say diferential) in the form of drawings lower down on the pdf
#10 |
for true balanced (two diffential) you have to cut the signal in half, one half with positive the other with nagative polarity and as long as the signal chain is separated and similar external noise intrusion (the commen mode signal) can be canceled anytime in a final differencial stage that cancels out unwanted noise (substrakt) and amplfies and conducts the signal (add)
| About the NAD s200 bal-input not balance? | Wizard | Solid State | 0 | 12th May 2007 07:11 PM |
| balance zen line stage input and output | hc167 | Pass Labs | 10 | 23rd October 2006 03:29 PM |
| Balance Input For Aleph-X | thomasfw | Pass Labs | 2 | 26th January 2005 04:35 PM |
| Converting balance to unbalanced input | diyman | Solid State | 4 | 7th March 2004 09:16 PM |
| How to convert Unbalance -> Balance Input ? | Minh | Solid State | 21 | 19th September 2002 11:09 AM |
| Page generated in 0.11114 seconds (72.28% PHP - 27.72% MySQL) with 11 queries |
