Old 15th November 2009, 08:12 PM   #11
tiefbassuebertr's Avatar
Originally Posted by gaetan8888 View Post
Hello
Here is a phono preamp using the LM318 but at pin 1 and 5 it use a super-matched LM394 transistors pair.
The LM318 are a fast op-amp with no rise of distortions in high frequency or at very low level, its an old but good op-amp.
There is more modern op-amps but most of them do have a strong rise of distortions in high frequency or at very low level.
This circuit use an external LTP input to keep the speed but not the noise.
Any opinions, ideas ?
Bye
Gaetan
I have found this circuit by a commercial preamp from "Musical Fidelity" without type number. The model was simply "The Preamplifier"
Old 15th November 2009, 08:15 PM   #12
Here the pdf schematic from this Musical Fidelity Preamplifier:
Old 16th November 2009, 03:02 AM   #13
Bonsai is online now Bonsai  Taiwan
Don't forget that starting at 2120Kz, the RIAA response drops off at 20dB/decade, so this makes the loop gain requirement less onerous than say an amplifer that has a flat transfer function. That said, there still some pretty good new op-amps out there (as listed in above threads) that will do an alright job. LT also published a design based on their LT1115 (IIRC) - you mught want to try googling that. Otherwise, Syn08 has some fine designs. Good luck.
bonsai
http://www.hifisonix.com/
Old 16th November 2009, 04:51 AM   #14
Hello
They use a similar ideas than the LM318 phono preamp with a LM394, but they use a NE5534 who are lower noise than the LM318.
Thank for this schematic.
Bye
Gaetan
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Phono preamp mm cartier20002000 Analogue Source 8 27th November 2007 03:17 AM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Which phono preamp ? yagoolar Tubes / Valves 5 26th January 2005 10:50 AM
MC phono preamp Vortex Tubes / Valves 29 29th March 2004 10:39 AM
Page generated in 0.14824 seconds (36.34% PHP - 63.66% MySQL) with 11 queries
