Ultimate MC RIAA phono pre for "Blue Oasis" (Win Research Group) schematic?
Old 10th November 2009, 05:55 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default Ultimate MC RIAA phono pre for "Blue Oasis" (Win Research Group) schematic?
For the cartridge "Blue Oasis" there are a special made MC pre amplifier from the brand
Sao Zaw Win (Win Research Group, Inc.)
formerly: Win Labs
7320 Hollister Avenue, Goleta, CA93117
Voice: (805) 968-5213. Fax: (805) 685-2781
information from 14 PDF- URL
http://www.theaudiocritic.com/back_i...ritic_17_r.pdf
For this device I need schematic and the IC "SL459" (SL 459) itself.
This IC is in use by the input stage (brand: Plessey). Datasheet unfortunately not online, but I have a original databook. Below you see a clone of the internal circuit (pdf schematic)
Perhaps one of the members know more about the currently brand name, additional about a delivery source for the "hard to find" part "SL-459".
Please note, only the outline of the SL459 is like a OP AMP (i. e. DIP-8) but not the internal topology.
A modification to the "easy to find" AD797 delivers not the sweet sonic performance than the SL-459.
Thank you for your advices.
Old 3rd December 2009, 06:12 PM   #2
Are there realy no informations ??
Old 18th February 2010, 04:48 PM   #3
schematics still wanted
Old 19th February 2010, 11:21 AM   #4
Scott594 is offline Scott594  United States
Plessey was sold to Mitel in 1998. Here are possible sources for the SL-459.
Linecard
http://www.class-ic.eu/Files/Linecard.pdf
wizard-final
220,221
Whatever it takes.
Old 6th August 2010, 02:28 PM   #5
kugel-balu is offline kugel-balu
Default Win Labs preamp McG-10
Hi folks,
I had one for repair, and had to deal with the input chip.
It is NOT an SL459, as stated, but an SL561C, also from
Plessey. Similar function, but rather different pinning.
If anybody opts for a repair or improvement, good points
to observe are the following:
- the other chip on the tiny IC board is an NE5532N, which should
be replaced by the lower noise version, or (perhaps) by the
more recent improved versions from National
- the power supply is built with 78L15 / 79L15, with very little
filtering -- which limits the result quite a bit
- the capacitors in the RIAA network were standard
MKT types (at least in my copy), with rather high tolerance
(I checked them -- some 10 % difference left to right),
perhaps better replaced by 1 nF and 3.3 nF styroflex
So, some room for improvement here really , but beware
that unmounting and re-mounting the Pre needs some experience ...
Hope that helps.
Old 19th April 2011, 08:36 AM   #6
Obviously your "McG-10" is an additional model from that brand, that I don't know this version. The version asked here for schematic is without type number and without model number (special made for the cartridge "Blue Oasis") and equipped with follow integrated circuits:
1) SL-459 (actually unknown because scratching out/polish off the type number, but pinning according the SL459)
2) NE5532
3) SG1468/1568 (dual tracking voltage regulator from Silicon General - see attached datasheet)
Genuine schematic diagram still wanted.
Old 31st August 2014, 02:49 PM   #7
any news?
Ultimate MC RIAA phono pre for "Blue Oasis" (Win Research Group) schematic?Hide this!Advertise here!
"TRANSCEND RESEARCH" Speakers Alan Borders Multi-Way 3 7th February 2018 07:28 PM
Kofi Annan in: "Cascodin' with Steve Bench's RIAA!" Kofi Annan Tubes / Valves 261 10th June 2011 05:48 PM
"All American" RIAA Preamp wrenchone Analogue Source 33 13th March 2008 07:05 AM
Alps "blue velvet" from mouser? djembe Parts 3 6th September 2006 01:43 PM
"Improved RIAA by Jax"-Power supply help needed!!! brigade77 Tubes / Valves 2 9th May 2006 05:04 PM
