| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
If you will replace the bearing oil clean the shaft and housing well.Start with a few drops of new oil and fit the sub platter slowly.If it goes down very easily,put a few more drops of oil,till the sub platter goes in slowly and some oil comes out of the housing.This way you'll be sure that the housing is filled completely.
#12 |
I got the AT110e today, set it up and dialled it in, and it sounds great. I expect it will take a while before it settles down and the highs get a little less bright, but it already sounds great!
I filled the bearing housing with sewing machine oil, but unfortunately there is a bit of movement in the platter when it's seated. There are two nylon bushes, and I think the lower one is pretty worn out, the top one fits very snugly. I am thinking of getting a new one made. What kind of clearance should I go for around the bearing shaft? If it all costs too much, I was going to find a Thorens TD 160 in the area, and fit my Linn arm. |
#13 |
Try a thicker oil.It is recommended for bearings with not so tight tolerances.
| Linn Lk1 | dw887 | Solid State | 13 | 6th April 2010 10:58 AM |
| LT1962 misbehaving - why? | stolbovoy | Parts | 5 | 27th October 2009 09:48 PM |
| Amplifier misbehaving when operated at B>1 | kipman725 | Solid State | 16 | 19th September 2009 09:05 PM |
| FA UK Linn Kan Mk1 | mr-mac | Swap Meet | 0 | 4th August 2008 09:12 PM |
| Help diagnose misbehaving aleph-x prototype | jwb | Pass Labs | 3 | 6th January 2003 02:57 AM |
| Page generated in 0.08127 seconds (66.85% PHP - 33.15% MySQL) with 11 queries |
