Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 4th November 2009, 07:45 AM   #1
Question problem with Grace g-940
Hi everyone
I am trying to set up my Grace G-940 arm; the unipivot. I bought it second hand some time ago and for so many reasons I haven't put it on my other TT (probably because I have been happy with my PS-X60 with PUA-7 tonearm).
Anyway, the pivot seems to lean to the right all the time. Does this mean it has jumped off the pivot? Run out of silicone oil? Or something far more mysterious?
Any assistance is greatly appreciated
Old 4th November 2009, 08:16 AM   #2
frugal-phile(tm)
planet10's Avatar
have you adjusted the lateral weight?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
Old 4th November 2009, 08:36 AM   #3
dave
yes, as far as I know. It appears the lateral balance weight is not heavy enough to straighten the tilt
Old 4th November 2009, 08:58 AM   #4
frugal-phile(tm)
planet10's Avatar
Then something is hanging up. What does the pivot point and the cup look like?
dave
Old 5th November 2009, 12:02 AM   #5
Thanks Dave. I will have a look inside. I was trying to see if there was a simpler solution but it seems not. C'est la vie
Old 6th November 2009, 04:49 PM   #6
brianco is offline brianco
Location: Scottish Borders - Kelso; on the famous Tweed River!
Have you checked that the wire between the pillar and the arm tube has enough freedom?
Old 6th November 2009, 05:15 PM   #7
kevinkr is offline kevinkr
Contributing
kevinkr's Avatar
I would also look around on Vinyl Engine | The Home of the Turntable, there is likely to be someone who may have a specific recommendation as to what the problem may be.
Is the Cartridge you are using in the recommended weight range? (not tracking force)
Kevin
www.kta-hifi.net
Old 8th November 2009, 09:12 AM   #8
thanks; looking at all the options. no cartridge at this stage, need to get it working properly first
Old 9th November 2009, 01:27 AM   #9
Contributing
kevinkr's Avatar
The fact that you have no cartridge installed may be the root of your problem. The uni-pivots I have owned all required a cartridge to be installed before adjustment of the lateral compensation weight resulted in proper playback geometry. Find an old cartridge or possibly purchase the one you intend to use and then try to set the arm up - I think you will find it works a lot better.
Kevin
www.kta-hifi.net
Old 9th November 2009, 04:28 AM   #10
frugal-phile(tm)
planet10's Avatar
I concur with Kevin. Without the mass of the catridge, it won't balance ...
dave
Thread Tools
Grace 707 help woody Analogue Source 10 23rd September 2007 02:15 AM
WTB: Grace 727/747 headshell slydwz Swap Meet 0 28th June 2005 02:41 PM
Grace F9E Keithj Analogue Source 6 19th July 2004 11:23 PM
Grace 707 ingvar ahlberg Analogue Source 9 21st March 2004 11:47 PM
Page generated in 0.18681097 seconds (83.65% PHP - 16.35% MySQL) with 12 queries
Copyright ©1999-2009 diyAudio
