Old 3rd January 2010, 04:18 PM   #341
Joachim Gerhard's Avatar
People at Revox (i know the design team very well) told me about the BF682. They got great results so you are in good company. As far as i can see from the data sheet they have between 25 and 40mS so some sorting may be needed. Idss varies a lot too, between 10 and 25mA.
Old 22nd May 2010, 08:28 PM   #342
kamis is offline kamis  Serbia
Syn08, how close parallel transistors (N to N and P to P ) should be matched in HPS-4.0 ? I wish to use Sanyo 2SC3601 and 2sa1407 of which I have many pairs, all E gain groups.
Old 22nd May 2010, 11:05 PM   #343
syn08 is offline syn08  Canada
Same beta class is more than enough. Just make sure you trim the pot to cancel the input current. It can be done down to 20nA.
Old 23rd May 2010, 09:28 AM   #344
Thank you. I think that HPS-4.0 pcb PT holes are not wide enaugh for TO-126 transistor leads.
Old 23rd May 2010, 03:16 PM   #345
Right, they are not.
All DHT Phono Stage Steve Cresswell Tubes / Valves 20 31st July 2009 06:03 PM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Phono Stage ruangrit Analogue Source 1 11th October 2003 11:13 AM
Page generated in 0.09547 seconds (64.30% PHP - 35.70% MySQL) with 11 queries
