MPP
MPP
Old 28th September 2013, 09:16 AM   #9511
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
An alternative is to use size AAA batteries. It is essential that they are parallel to each other and that they are placed on a hard, smooth surface (plate glass is best). They also MUST provide front to back freedom which is in exactly the same direction as the cone's movements. You must first peel off the outer paper/plastic so that the metal can is fully exposed and clean of lumps and bumps. I no longer bother with such niceties as my hearing has degenerated so much that the benefits of such work are subjectively so marginal as to be no longer worth the effort. I do still use carbon blocks under all equipment and this is worth the effort. the floor of my room is fully floating and the hardware - other than speakers - is in an adjoining room.
Old 29th September 2013, 07:05 PM   #9512
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
I used to peel off the aaa's and then paint them in mat black varnish.... When I was young and bold.
RC
Old 29th September 2013, 09:06 PM   #9513
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I will of cause not show the squeaky yellow tennis balls in public. They stir much too much attention.
Here is the " beautified " version. I spray them black and put them in a silicon rubber hose. That hose also helps to stop the tennis balls rolling but does not affect the vertical decoupling much.
Old 30th September 2013, 01:43 AM   #9514
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Of course the question on everyone's mind, is selecting the very best sounding tennis balls!
They come in three varieties, so which is best?
Grass Court?
Clay Court?
Concrete Court?
P.S.
Here's a photo without the yellow. They don't seem to collect scrutiny when the color is light/medium gray.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 30th September 2013, 02:06 AM   #9515
I could only get that type of tennis ball in the small town i life.
I have no doubt that different varieties sound different. Also the silicon hose made a difference. It sounded more snappy and dynamic.
Old 30th September 2013, 02:08 AM   #9516
yeeh, i like that black and white rendering.
The speakers could have being used in a Hitchkock film.
Old 30th September 2013, 07:29 AM   #9517
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Does the ATL have a patent on that? (Provided by Obi-Brilon I think (the brother of Obi-Wan Kenobi - Wikipedia, the free encyclopedia)).
Old 30th September 2013, 04:25 PM   #9518
For a patent it is too late but i will not disclose the proprietary technology to get the ball in.
Old 30th September 2013, 04:39 PM   #9519
MiiB is offline MiiB  Denmark
too late for that too...
Old 4th October 2013, 03:29 AM   #9520
http://www.cieri.net/Documenti/Kenwo...al%20Guide.pdf
MPPHide this!Advertise here!
