Mpp
Mpp
Old 1st August 2013, 02:28 PM   #9411
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Yes, you inspired me to design it and i learned from you.
MiiB even build a balanced version. In his version the current for the input stage is supplied by solar panels i think. The panels are in a closed box and bulbs light the panels.
He had quite a few problems with heat.
Old 1st August 2013, 03:05 PM   #9412
keantoken is offline keantoken  United States
keantoken's Avatar
Here is what I've come up with. This preserves the natural focus of the buffer. I'm not sure why. As you can see I used a toroidal coil to rule out interference (and also just for fun). The coil I used is actually 500nH, but 2uH is what it takes for unconditional stability, and still sounds great. You don't necessarily need the 47R output resistor, but it keeps the cable from resonating too bad, and it is something I hesitate to leave out of any buffer.
I tried switching the collector of Q1 to the emitter of Q2. This sounds very good, but has .01% THD with H2 at -80db. I thought it may have better focus but I'm really not sure. In any case the effect is very enjoyable. However ultimately I settled on this version for sounding more accurate in general, to me at least, and having less distortion.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 1st August 2013, 04:47 PM   #9413
Ok, i will build it.
Old 1st August 2013, 06:03 PM   #9414
smms73 is offline smms73  Portugal
smms73's Avatar
Joachim, I have also learned a lot from you, especially in controlling noise.
It is for me a honor , to have inspired you in creating such a nice circuit.
SÚrgio Santos
Old 1st August 2013, 07:42 PM   #9415
My pleasure.
Old 1st August 2013, 07:43 PM   #9416
It is in use at Zellaton at the moment.
Old 1st August 2013, 07:44 PM   #9417
Sorry the came out " on the head ".
Old 2nd August 2013, 06:47 PM   #9418
This is not analog but interesting nevertheless :
SRC Comparisons
Old 2nd August 2013, 07:28 PM   #9419
I rebuild one channel of the Kean buffer to latest specs.
It worked right away. It is darn hot here so i need a break. I will build the other cannel later and then listen.
Old 2nd August 2013, 07:48 PM   #9420
keantoken's Avatar
I use an FFT resampler that was a little hard to get. Most resamplers use varying kinds of interpolation which can only be approximate. "Oversampling" on DACs is still some kind of interpolation. FFT resampling in a DAC would require a microprocessor to apply the FFT algorithm. Using an FFT however allows a much more exact conversion. It seems more and more producers are considering this.
The worst errors occur when converting between 44.1k and 48k. I helped with the development of Synthfont (MIDI sampler/sequencer) and suggested to the developer to include an FFT resampling algorithm. Since most of the samples available are 48k or 44.1k, this improved resampling quite a bit and really helped to reduce that "MIDI sound". This is very important for sequenced music.
2L has put up some music samples that were resampled using a "saracon" resampler, which I guess is popular. I wrote an email pointing out the heterodynes in the spectrogram compared to the non-resampled version but did not receive a response.
I get a kick out of playing their 350KHz samplerate files, FFT resampled to 192KHz. I don't think this has much to do with the samplerate, but I think the 2L recordings are still really great.
As far as sample conversion however, the most interesting thing to me is that the largest audible effect seems to be in the bass and lower midrange, not necessarily the treble where you would think.
MppHide this!Advertise here!
