MPP
MPP
Old 14th July 2013, 01:15 AM   #9361
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I supply the Kean double mono. Each channel has its separate set of batteries.
I do the square wave overshot trick too sometimes. I then use a single, well damped overshot. That can give the impression of more speed, dynamics and focus.
I know that. I just would not do it on the prototype because it is strong medicine.
Old 14th July 2013, 03:49 AM   #9362
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
That seems like good news.
Kean has several buffers, but this one is called: Kuartlotron
For some or no reason, it took me about 6 months before successfully memorizing how to spell it.
Just a note. If the Kuartlotron happens to lose the contest on account of focus, you can switch the outputs to BC556C, BC546C or BC550C, BC560C to slightly increase the focus at some slight cost to tone function, quite proportionately too. A very minor change indeed. But, more "focus" really is available by exchanging the medium signal outputs for small signal outputs instead.
Also, both trimmers, R1 and R5, can change the "focus" and tone a little bit, so if you're highly sensitive to those functions then you might want to have the trimmers installed for adjustment.
I probably don't know anything else about this circuit. Yeah, that was it.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 14th July 2013, 04:03 AM   #9363
Thanks, i did not trim so far but i will.
Have now made both channels the same and will listen.
Old 14th July 2013, 04:57 AM   #9364
focus restored.
What i can say is that the Kean buffer sounds exceptionally sweet without loosing detail.
Music sounds really different and new to me.
Old 14th July 2013, 01:29 PM   #9365
keantoken is online now keantoken  United States
keantoken's Avatar
Thanks Joachim.
If you used the 56R (or 47R rather) resistors, then I'm guessing you built it as per the schematic, with BC550C NPN's.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 14th July 2013, 01:49 PM   #9366
Yes. I will do more listening today.
Old 18th July 2013, 10:39 AM   #9367
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Joachim, here is a link to the tonearm I am working on. SUPEX AL-2 Tonearm lift repair
I believe it is a Micro Seiki modified.... Any hints on fluids would be very welcome.
PS: sorry for the off topic.
RC
Old 18th July 2013, 12:42 PM   #9368
That Supex arm looks like a Fidelity Research.
Old 18th July 2013, 08:14 PM   #9369
nhinstruments
RCruz's Avatar
MPP
Mr. Ikeda owns Fidelity Research I believe.
RC
Old 18th July 2013, 08:29 PM   #9370
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
HAving never heard of a Supex arm, I googled and found that the reference applies only to a lift/lower device. The arm shown is some hybrid I guess loosely based on the WTA, but its damped lift/lower device is very similar to that on the FR arm which is shown in the last picture. It is that part alone which is 'Supex' from what I can find.
Fidelity Research ceased production many years ago. The same man then designed an updated version which is the Ikeda arm. I had a few FR64S arms over the years and they were excellent with low compliance MCs. Indeed the FR 700/701 MCs were brilliant in my view and so musical. I converted one by removing it from it's FR headshell/casing and fixed it in a solid Audio Tekne style head-shell. That one was the best. All of this I obtained from the old UK importer when FR stopped production and it was their entire review stock. ...but the 66S had already gone elsewhere!!
MPPHide this!Advertise here!
