MPP
MPP
Old 28th June 2013, 07:46 PM   #9161
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I have Keantoken cap multipliers and on board RC filters.
Other then that i will try to supply this schebang with a Traco SMPS.
I already tried this on the Curryman DA converter and it works great with some care.
I get tired to build big tansformer, doide, cap PSUs.
Old 28th June 2013, 10:47 PM   #9162
smms73 is offline smms73  Portugal
smms73's Avatar
Good luck Joachim . I look forward to see the results. Good weekend.
Sérgio Santos
Old 28th June 2013, 10:54 PM   #9163
Old 30th June 2013, 09:09 AM   #9164
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
The army of gadgets is growing.
Kerli - Army Of Love - YouTube
Old 4th July 2013, 12:30 AM   #9165
Paradise
Sade - Paradise - Oracle Arena, Oakland, CA - 8/27/2011 - YouTube
Old 4th July 2013, 12:39 AM   #9166
BILLY COBHAM STRATUS - YouTube
Old 4th July 2013, 08:53 AM   #9167
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Youtube. This irks me a bit. So, I publish a lovely fresh sounding analog compressor, the clipnipper, which does not get any press. And then, ironically and annoyingly, Youtube uses the nasty cheapskate sort of digital compressor that sounds like a fuzzbox. Perhaps it is appropriate for assisting iphone speakers to play a few decibels louder than before.
That might not be the best website choice to illustrate what music is supposed to sound like--they usually screw it up. Maybe SA Stereo Tool filter can remove some of the damage?
Or, an analogue option. . .
It is a strange thing that some amplifier topologies can post process a little bit, to somehow remove some of the digital fuzz without removing the music. A shunt comp preamp might could manage an artificially deep noise floor. Likewise, but backwards, a high gain old Miller amp could manage a dynamics expansion if the speaker return direct-connects into the amplifier board, to jolt it, precisely, and on purpose (a mild form of Armstrong Boost, which is so much fun and not always mild). In combination, and despite the probably excessive system gain, I wonder if the pair could remove the YouTube "digifuzz" distortion or at least make a more convincing and less compressed presentation? So far, so good. But it would have been easier if Youtube had not added yet more compression of such weird quality, as if anti-imaging or flattening (that I don't like).
And then the question:
That shunt comp preamp that could make the quiet quieter? Can it be used as the rail splitter and/or regs in power supply duties? I suppose that should be quite successful. It may be worth the parts count.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 4th July 2013, 09:16 AM   #9168
keantoken is offline keantoken  United States
keantoken's Avatar
Dan, it sounds like you're asking for a special kind of opamp. The thing is, low treble distortion tends to mean conditional stability into capacitive loads, hence necessitating an L/R at the output. For this reason an opamp that could work both as a reg and as a preamp would require careful design. But it is an intriguing challenge. You could ask the guys here about it:
http://www.diyaudio.com/forums/analo...design-59.html
For a rail splitter, I would use an opamp and filter it's supply pins to improve PSRR. I was going to say that opamps have worse PSRR than chip regs, but then I realized I'm not really sure about that... Maybe certain opamps would be an advantage if used as regulators, owing to their speed?
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 4th July 2013, 03:54 PM   #9169
smms73's Avatar
Default Cap multiplier
Today I was testing my shunt regulator that has a Pré-regulator, and I realize (remember) that when one use a pré-regulator there is no need for a great PSRR as the total PSRR is the sum of the pré-reg PSRR and the main-reg PSRR.
And, I want to design a new regulator for my headphones amplifier, that works in class A and consumes 50mA per channel.
So, I went to ltspice, and try to improve the output impedance of the Keantoken multiplier.
This is what I have right now. It uses the FdW current source. the bc337 will be good for at least 100mA, as the voltage at collector-emitter of Q1 is only 2 volts.
Q1 ,Q2 and R1 can be substituted by a Darlington. Diode D4 serves to fast charge the capacitor C2. I tried not to use exotic/hard to find componentes.
Improvement proposals are wellcome.
The first picture is the simplified circuit, and the second the full circuit without the pré-regulator, that is based on a lm317/337. The load current is 50mA
Sérgio Santos
Old 4th July 2013, 04:13 PM   #9170
smms73's Avatar
You can put a large capacitor in the output of a opamp , larger than 100uf. If the capacitor is too small or low esr the opamp can oscillate..
The ess reference DAC board has regulators based on this, I have tested with opa2134 and works good.
normally opamps have better PSRR than reg chips , new designs have better than 120db.
Sérgio Santos
MPPHide this!Advertise here!
