Mpp
Mpp
Old 23rd June 2013, 11:58 AM   #9021
hesener is offline hesener  Germany
Mpp
Originally Posted by Joachim Gerhard View Post
Here is the variety of the K-multiplier i used in the headphone amp. The negative one is build the same way. Do you think it is dimensined resonable ?
Circuit 2 shows a more conventional circuit i would like to build for comparison. It came out of the simulator well. I see the main advantage of circuit 2 in the use of a quite small shunt cap. There is a really small 4.7uF Wima foil so it could work without electrolytics.
Circuit 1 will need a higher input voltage compared to circuit 2.... how about using a CCS instead of the diodes that connect to the base of the NPN? A simple JFET might be enough, and give tons of noise isolation....
Paradise documents are here: Link list
Old 23rd June 2013, 12:06 PM   #9022
keantoken is offline keantoken  United States
keantoken's Avatar
The circuits should have very similar voltage drop because of the 17uA base current. 17uA through 3 diodes is 1.2V. 17uA through 68k is also 1.2V.
A CCS won't improve noise isolation because it is the Early effect of the driver that limits that. More filtering for the reference is not an improvement except at bass or subsonics.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 23rd June 2013, 12:24 PM   #9023
FdW is offline FdW  Netherlands
FdW's Avatar
Mpp
That is exactly true, the circuits where tuned to exactly the same output voltage (the difference in the simulation is only 16mV). (post #9007 left).
Edit: Oops... this is about #9016 (the output voltages of left and right are about the same). Joachim will build and analyze both lets wait and see...
Old 23rd June 2013, 01:32 PM   #9024
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Mpp
Originally Posted by sq225917 View Post
Jackinnj, what is the second reg in your example?
The Jung Regulator with LM317 pre-regulator and AD825AR error amplifier.
Old 23rd June 2013, 02:06 PM   #9025
MiiB is offline MiiB  Denmark
I do have a preference for making R-C og L-C type of circuits, where the PSU impedance mainly relies on single passive components.
I once made a DAC with a tube rectified power supply. And i must say the blackness and tone colors I got there was truly outstanding.
Tube rectifiers really eliminates diode switching noise.
Old 23rd June 2013, 02:28 PM   #9026
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I will now build the two circuits, both with 47 Ohm to supply the pass transistors.
I have no problem to understand you Keantoken but you look at this circuit from another angle. For example i have seen other cap multipliers that have massive filtering of the base current. You are the first one that said that filtering is limited by the early voltage ( at higher frequencies ) and i have to digest this.
Old 23rd June 2013, 02:29 PM   #9027
Here is an example of massive filtering :
Old 23rd June 2013, 02:34 PM   #9028
Here is another example with conventional darlington :
Capacitance Multiplier Power Supply Filter
Old 23rd June 2013, 02:57 PM   #9029
FdW's Avatar
Mpp
Using a darlington makes for a larger voltage drop and thus a lower value of the filter resistor (or both, or any of these )
Old 23rd June 2013, 03:01 PM   #9030
FdW's Avatar
Mpp
The LM needs 5V drop and the multiplier is configured for 10% that is a lot to drop and I do not see very great benefits. If you want a absolutely stable voltage, and you are spending all these components, also the complexity, then a Jung 2000 Regulator may be a better bet.
MppHide this!Advertise here!
