| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
| Thread Tools | Search this Thread |
#81 |
i may do a version that needs some more like 100ma too has the value to be exact ?
#82 |
i can buy the hammond from digikey if mundorf can not do it it`s HUGE i had no idea but if it does the job it`s fine for me do you think they could also wind it on a ferrite bobbin ?
#83 |
diyAudio Chief Moderator
You don't need a monster, the Hammonds are pretty small n' cheap. Show them the datasheet asking for something like the 159ZA which is about 10x7x6cm. If they raise an eyebrow, just order 2pcs 159ZA online. In phono we need the RF out. Then the CCS won't need to be elaborate cascode and rather dry sonically. You will make perfboard reg prototypes, yes?
#84 | |
You will only need to prefilter with 10.000uF-159ZA-10.000uF Epcos best, no plastic bypasses, down to 25VDC reg in +/- . Double mono. 2 preferably R-Core 100W Tx and 2 soft recovery bridges. All that in a separate box. Shunts litterally on load. No wires, or just 2-3cm thick ones. Else you should use force/sense wiring. OK will send you a symmetric of proper reg CCT.
#85 |
if you send me the artwork i can etch pcb´s but of cause i can do it also "free air" or on terminal strips anyway i am quite good with my hands if she says so
#86 |
I do them p2p, they do better that way. They are very simple ccts, and you can squeeze parts together avoiding nH thin copper pcb lines, also having air as dielectric. Superior subjectively. Will send soon. I want those for my bedroom in return. You can surely ask the fellow German speaker guys to wrap a little present to Athens, yes?
#87 |
yes thoose are good i taked to the designer he has great knowlage .
unfortunately active speakers do not sell well in high end circles. anyway i will come up with a present. where should i send it ? good night, i go to bed |
#88 | |
jd
/Another new issue: Linear Audio Volume 3! |
#89 | |
2012, our time is running out. |
#90 |
i have the n-channel and the dual here, thanks for informig me about the p-channel.
to scott : i will try out one of the circuits you meant. maybe the fet type. i just came back from austria, i was on a show in vienna. it`s beautifull. have you ever been in austria ? they have great food there and really love music. maybe you have the music gene too |
| Currently Active Users Viewing This Thread: 5 (4 members and 1 guests) | |
| fennek, hesener, FdW, Horton |
| Page generated in 0.15890 seconds (56.26% PHP - 43.74% MySQL) with 10 queries |
