MPP
MPP
Old 27th May 2013, 01:14 PM   #8971
gpapag is offline gpapag  Greece
gpapag's Avatar
MPP
Good.
Let's see if they will offer it at a fraction of the previous price and how other manufacturers will respond.
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 27th May 2013, 03:31 PM   #8972
gpapag's Avatar
MPP
3D printing
Joachim
Think of a speaker cone with material formulation changing from center to periphery, cone-surround too as one-piece construction.
George
Old 27th May 2013, 04:46 PM   #8973
MiiB is offline MiiB  Denmark
I have worked quite extensively with different types of rapid prototyping, To be honest the precision and the materials are not very good, the epoxy used in the Tonearm, is very prone to absorb moisture, and over time it warps, like a vinyl record subjected to heat. there are some materials that performs a bit better and some additive laser based sintering that can produce quite good parts, but there you also have to pay the bill. I made an arm tube with integral structures printed in Titanium.. bill was more than 1000 dollars for one tube, that was even without the 3D file preparation that was done out of courtesy by the facility. Orthfon prints their cartridge bodies this way, MC-Anna is the last example.
Old 27th May 2013, 05:31 PM   #8974
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
You likely meant melting (3D selective laser melting), instead of printing (sla).
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 27th May 2013, 05:36 PM   #8975
It's really laser welding in a oxygen protected environment. The process welds titanium layer by layer, into a solid structure. app 15-20 layers pr mm. Something similar is done in UV cured materials/resins and also in thermoplastic powders, but items are not to be confused with real processed materials.
Old 27th May 2013, 08:30 PM   #8976
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
http://www.blazelabs.com/l-vacuum.asp
Old 2nd June 2013, 06:59 AM   #8977
av-trouvaille is offline av-trouvaille  Netherlands
In post 8939 of the thread as a casual remark an inductive tube PSU of Andrejs is mentioned:
MPP
In a classical tubed power supply normally a choke is used, so I assume with ‘inductive’ is meant something else, maybe: phase consistent? Can someone please comment, or provide a link to contact Andrejs?
Old 6th June 2013, 02:21 PM   #8978
Here you can see measurements on electrolytics :
Audio-Kondensatoren, HiFi-Bauteile, Audio-Elkos
Old 7th June 2013, 09:12 AM   #8979
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Thank you... love caps
RC
Old 7th June 2013, 07:27 PM   #8980
More info on elcaps :
http://www.cde.com/catalogs/AEappGUIDE.pdf
Real bipolars can be quite good.
MPPHide this!Advertise here!
