Mpp - Page 884 - diyAudio
Old 14th April 2013, 07:17 PM   #8831
keantoken's Avatar
The BC5xx have good quasi-sat for both polarities. The A1015/C1815 do not. So don't use the latter for current mirrors. Try changing back to BC5xx for just the current mirrors and see what happens.
Actually, BC550/A1015 may be a great complimentary combination where high Hfe and good quasi-sat behavior are the top priorities.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 14th April 2013, 07:29 PM   #8832
Telstar is offline Telstar  Italy
Originally Posted by Joachim Gerhard View Post
You could learn LT spice. That circuit can be trimmed.
The circuit is not mine, I just changed some values and the output stage, to use the readily available PCB.
I'm learning spice (among other things) btw.
Kean: I need to get BC550B and higher grade toshibas to match them otherwise 500 and 200 hfe doesnt sound that good but it's an interesting idea. There are all BC mounted, exactly as in the schematic I posted in the linked thread.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 14th April 2013, 07:57 PM   #8833
keantoken's Avatar
Telstar, as I recall the greatest thing to improve THD was to make the current mirror gain as equal as possible, IE get R2/R11 as close as possible, increasing gain in other parts of the amplifier. The current mirrors should provide the LEAST amount of the total gain, rather than most of it. Unless you fix this it's unlikely that swapping transistors will change much.
Old 14th April 2013, 09:06 PM   #8834
Yeah, I agree. I'll leave it like it is, and just evaluate the sound.
I'll go work to the Marsh and my own design shortly.
Old 15th April 2013, 06:17 PM   #8835
keantoken's Avatar
Joachim, do you think you could do quasi-sat and linearity tests on some RF transistors like the BF240 and BF199? Or the BFG198/194? I don't know of a lot of transistors in this category so I couldn't pick out a complimentary pair.
One parameter that interests me for many transistors is log conformity, but that is even less useful than quasi-sat measurements, for most things.
Old 15th April 2013, 07:04 PM   #8836
Joachim Gerhard's Avatar
I do not know if i have that types. I have other RF transistors.
I plan to do some more measurements anyway.
Old 16th April 2013, 02:18 PM   #8837
Is Apple Preparing To Offer High-Resolution Music? - hypebot
Old 16th April 2013, 03:48 PM   #8838
Originally Posted by Telstar View Post
In the HP amp i'm toying with I'm using the BC550C/560C almost everywhere for simplicity. Cordell models are clearly very optimistic, but I adjusted the hfe to the one I have measured and they are very consistent (i believe I have either onsemi or fairchild production, since they were bought from USA).
The 2SA1015/2SC1815 both Y-grade that I have about a hundred pieces are much less consistent, probably GR grade would be more similar to the high BC"C" current gain. I didnt test all nor trace all, but I have the same Peak device (btw get the new firmware/sw is more detailed ^^) and I could do that.
I believe to not have very good models of them, or at least not optimistic as the ones I have for the BC. As drop-in spice simulation worsens the THD.
They run at around 10mA as drivers, so I think I should try as replacement for the BC550/560 as i thought Unfortunately I dont have a spectrum analyzer nor a very low distortion oscillator yet.
The toshiba pair have higher early voltage so would have lower distortion but this only at lower frequencies than say 1 Khz. Above those frequencies their higher Cob will cause higher distortion than the BCs. What you should do with the Kumisa design is use baxandall super pair as the vas. Not only is loopgain increased but its more linear and vas temperature is more stable due to the vbe´s cancelling. I dont believe the current mirror plays any part in lowering THD and the same can be had without its use.
Old 20th April 2013, 01:21 PM   #8839
http://www.vertereacoustics.com/wp-c...ocFile13ss.pdf
Old 20th April 2013, 03:10 PM   #8840
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
35000$
"Without deviations from the norm, progress is not possible" - Frank Zappa
Copyright ©1999-2017 diyAudio
