Mpp - Page 874 - diyAudio
Old 30th March 2013, 11:55 PM   #8731
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Originally Posted by Joachim Gerhard View Post
The major flaw of the Wheaton is a beam resonance at ca.300Hz.
I think that gives it this robust tone..............
Thank you for that Joachim as it may explain a problem I had a few years ago.
I used a Tri-PLanar MKIV (the first fat tube one) with SPU and Io cartridges. The bearings would unlock after about an hour. I knew that those cartridges were producing a lot of mechanical energy and maybe the beam resonance hastened the un-screwing of the bearings? I went back to a Zeta and a heavy unipivot. But, when all was well the Wheaton was very good.
Old 30th March 2013, 11:57 PM   #8732
Joachim Gerhard's Avatar
When i measure the frequency response of a cartridge in my Wheaton there is a small "blimp" there. There is another way to measure the beam resonance. That is with a lead weight on a string. I published both measurements here before.
It is not a big deal.
Old 31st March 2013, 12:11 AM   #8733
AVWERK is offline AVWERK  United States
AVWERK's Avatar
You can also place another arm and cartridge on top of the headshell and adjust accordingly the tracking weight, and note the output of the combo placed on top.
Kind of a cheap poor mans strain gauge
Been awhile since I have done it though
Old 31st March 2013, 01:43 AM   #8734
Here are some measurements on beam resonances :
FX-R
Obviously a triangle is the most stable shape.
Old 2nd April 2013, 06:18 PM   #8735
I got a Quantum Asylum Audio Analyzer.
I made a loop back measurement and got the 3rd harmonic at ca.-105dB. That is around 10dB worse then Audio Precission teritory but 10dB better then i get with my E-MU 0202USB so i think this is usefull.
Just for fun i measured the B1 buffer i build quite a long time ago.
At ca 1.3V RMS ( around 4V P-P ) i get around -95dB distortion. I think for something so simple this is very good. I also show distortion at lower volume and the volume where the third disappeares in the noise. The first picture is a loop back measurement of the analyzer.
The last picture is intermodulation with a 10kHz -10dB sine mixed in.
Old 2nd April 2013, 07:27 PM   #8736
Nice tool
Would you mind to measure also the "JG" buffer used in the DAC filter buffer? Just for fun
Old 2nd April 2013, 09:06 PM   #8737
If i had one in isolation, yes.
I have it on the XEN ESS board and on the Paradise.
We simulated it though and it has ( much ) lower distortion provided it is not driven out of class A or voltage overdriven.
I can make an even better buffer especially if more voltage and current is needed.
The attractive thing with the BF862 based version is the extreme compactness.
Old 2nd April 2013, 09:10 PM   #8738
Concerning measurements, an AD797 buffer with common mode compensation would have no measurable distortion, even on an AP. Does it sound better ?
I think the success, subjectively, of my buffer-filter is the extreme simplicity combined with the good performance.
I do not think that static distortion measurements tell us all about the sound.
I wish it would be that easy.
Old 3rd April 2013, 01:12 AM   #8739
MiiB is offline MiiB  Denmark
No you solden"t, if i was that easy, Them there would be no room for you, or for me..
Old 3rd April 2013, 07:22 AM   #8740
I am fully aware of the fact that good numbers do not necessarily correlate with good sound. I just wanted to get an idea of the measured performance of the buffer.
I was too lazy to simulate it on my own. If I would have done it, I would have seen that the buffers distortion figures will probably not be measurable with the given equipment Just found the thread from calvin about preamp buffers with simulation results.
The subjectively perceived quality I know very well
Copyright 1999-2017 diyAudio
