MPP
MPP
Old 14th March 2013, 10:14 AM   #8511
Joachim Gerhard is online now Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Stefanoo is convinced the the Teflon-copper V-caps are superior to anything else.
I can not commend on this. I simply have not tried them.
There is one person i trust, Hesener, that also bought a set of V-Caps so i await his response.
buzzford there is no new schematic that i am aware of. I started to work on a single ended Hybrid ( Fet, BJT, Tube ) phono coined Cro Magnon but i will not proceed with that project.
Where i am working on is a balanced input for the Paradise. That is in the beta stage.
Maybe today i will finish basic input stage. If i can get it work satisfactory i will explore
the option to fit it into the Paradise.
Stefanoo has opened a tread called " Masterpiece" in an attempt to better the Paradise.
Unfortunately he did not come up with a schematic so far. What he did instead was asking for help and schematics from me, MIIB and others. We gave him some hints and circuits but nothing seem to satisfy him. Also i do not feel obliged to make him a circuit.
That resulted in his comment that the contribution of MIIB was useless.
Fortunately he did not attack me directly so i am still willing to contribute on the Masterpiece thread. I am just not willing to do all the design work.
Stefanoo claims that he has a superior sound system and extremely good ears.
He said the Paradise is ill difined in the bass, sounds tired and does not resolve well in the treble.
He does not tell what recordings he uses plus what the alternative, better sounding phono stage is. He likes the big Audio Research Ref and the Boulder but i have no idea if he has them home.
SMD transistors : i think Zetex makes very good ones. Some posts ago i have mentined a pair that is low noise and high Hfe. I just can not remember the names.
Old 14th March 2013, 10:19 AM   #8512
I use Polystyren caps in my RIAAs sometimes bypassed with teflon trimmers.
I also use Roederstein P-P and Mundorf silver-gold-oil.
Also RIFA PHE426 and RIFA PPS SMD.
All of this caps have very low distortion, sure under -120dB so when the V-Caps sound better it must be another reason.
I do not think that it is dielectric absorption or ERS.
In the Paradise the RIAA caps are driven by a high impedance constant current source ( the mirrors). That swaps any small parasitic there will be.
Old 14th March 2013, 10:24 AM   #8513
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Hi buzz... are you planning to build the paradise with SMD trannies ?
PS: styroflex are quite stable but difficult to handle due to it's sensivity to heat.
Teflon is even more stable but the "nice" ones are very expensive.
I am now building a rig with russian NOS teflons (inexpensive but bulky) and report back.
I allready experimented with teflon in the riaa circuit and found very good extension but somehow lacking in "body".
Untill now, my preference is with polystyrene and tin foil. These are full bodied, sweet sounding with ultra minute detail.
Plain styroflex (polystyrene on alu foil) can sound dry.
Micas are really speedy and provide loads of detail but can sound edgy.
RC
Old 14th March 2013, 10:28 AM   #8514
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Funny, that is the exact opposite description that i have hard from everyone else. Anyhow. It must have been the balanced version i saw. I have been looking at this also, not because of superiority, just fun. I have folded simplsitic now, and haev your Paradise in the batters box. Thanks about the recommendations. I looking at NOS polystyrenes recommended by Jacco. He is a walking part catalogue. Ill give a look at the ones you mentioned.
...Shape the sound , Man!
Old 14th March 2013, 10:31 AM   #8515
buzzforb's Avatar
I purchased some of the old FT series teflon, as you did. Haven't tried them yet. SpaceEggCorp tesetd some of the older teflons and showed they were not so well suited for RIAA, but i forget which ones he tried. I am really digging this SMD thing. Its all about fun, you just get the byproduct of amazing performance. Vishay PLT have ppm of 5. WHAT! I may try some form of SMD RIAA, but not for a while. I was asking about low noise bjt's for output stage of balanced pre.
Old 14th March 2013, 11:00 AM   #8516
You can try Zetex FMMT618TA, 718TA.
Beware that they have only 20V Vce.
There are versions of this transistors that can stand more voltage.
For example FMMT619, 719 can stand 40V.
There are some that have even more.
You can find that in the data sheet.
Old 14th March 2013, 11:02 AM   #8517
here :
FMMT618 Datasheet pdf - NPN Low Sat Transistor - Zetex Semiconductors
I also find that Stefanoos description of the Paradise sound is wrong.
I find it sounds very dynanic and open.
Old 14th March 2013, 11:02 AM   #8518
buzzforb's Avatar
Thank you. One last question. Have you ever given PPS caps a try? Superior stabiltiy, but doesn't say much for their sound.
Old 14th March 2013, 11:16 AM   #8519
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
MPP
I've deleted a couple of posts. I've also Suggested to Stefanoo that he has made his opinion known and should move on. For that to be successful I would appreciate it if no one else takes him to task over his statements.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 14th March 2013, 11:17 AM   #8520
I use RIFA PPS SMD all the time.
I think they have " no sound ".
That was also the opinion of Allen Wright ( RIP ) of Vacuum State.
I can tell you that guy was a tweak master.
His Real Time Preamp landed several times in the reference class. There are some that think that this is the best Preamp ever made.
The only problem with the PPS SMDs is that they are not easy to get at better then 5% tolerance. I found in praxis that they match better then this.
I select and measure all of my RIAA caps anyway.
MPPHide this!Advertise here!
