Mpp
Mpp
Old 26th February 2013, 10:48 AM   #8401
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I think for MM we have to reduce the idle, from the standpoint of current noise and also because of the input impedance.
Old 27th February 2013, 05:22 PM   #8402
MiiB is offline MiiB  Denmark
I have the RiAA Values for a 42-44 dB gain circuit. idle reduction can be done by alteration in in central CCS. What kind of current would you want through the input transistors..??
Personally I dont think anr current reduction is needed as the driving signal is so much stronger, the noise suppression will still be enoumous, but off course the input impedance will be an issue.
Old 27th February 2013, 06:30 PM   #8403
The " natural " input impedance of the Paradise is around 10kOhm.
That is too low for MM. I would like it to be at least more then 50kOhm.
The problem is that reduced idle will then also reduce the amount of current that we can dump into the RIIA worsening distortion. On the other hand we have lesss gain and that brings the performance back. Kind of juggling. We COULD of cause use Fets at the input with only a small change in topology.
Old 28th February 2013, 08:49 PM   #8404
This could be usefull for servo :
http://de.mouser.com/pdfdocs/opa2180.pdf
Old 28th February 2013, 11:37 PM   #8405
Bksabath is offline Bksabath  United Kingdom
Banned
Hey that wuld be just perfect for one of those...
http://www.acton-gate-audio.co.uk/pr...uctName=Sumiko Blue Point Special&ProductID=2903
Was tempted to get one especialy for the 35dB channel separation.
Old 7th March 2013, 06:44 PM   #8406
good old stuff :
http://www.ax84.com/static/rdh4/chapte17.pdf
Old 9th March 2013, 01:47 AM   #8407
A new structure that could substitute tubes :
Electron field emitter technology to improve imaging, communications
Old 9th March 2013, 04:11 AM   #8408
GaryB is offline GaryB  United States
Mpp
Default Vacuum transistors
There was recently a seminar where NASA researchers presented an overview of their work on vacuum tubes built on the nanoscale. Very interesting stuff. Slides here: http://sites.ieee.org/sfbanano/files...9_modified.pdf
---Gary
Old 9th March 2013, 04:19 AM   #8409
I like the term : " Premier Audio"
MppHide this!Advertise here!
