Old 17th February 2013, 12:55 PM   #8361
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
An extra small concern may be the high burden voltage in some DMMs (the voltage drop in their "shunt" current measuring resistor) for their mA range. You can test that by measuring the red mA range terminal with a DMMs red probe when set for Ohm. Don't be surprised if finding 10 Ohm+. Combine all that and you may need VDD+ to really measure at 10V across the JFET in current mode test. One of the reasons the FETS bias somewhat harder than expected when put in PCB. Can be a problem or not depending on the circuitry concept and the JFET type curve. Some don't change much their IDSS over 2V, other types may do. It can be enough of a concern if measuring IDSS at low VDD for near 2*Pinch off VDS use for instance.
Old 17th February 2013, 01:28 PM   #8362
Joachim Gerhard's Avatar
Before i used a curve tracer i measured with 18V and a 1kOhm resistor.
Old 17th February 2013, 01:56 PM   #8363
Bksabath's Avatar
Tanks Joachim and Salas
18V and 1 K sound fine besides Paradise runs at 18 V so even better
PS
I have a Little test rig for HFE tanks to Hesener for help on that one
The circuit I have posted came out of Salas Simplistic tread
I am drowing a PCB to include those 2 test circuits + Led Voltage tester and VBE tester
Again Led voltage is out of Simplistic and VBE test is one I have posted a while ago (apolologies due as can't recall source for that)
VBE test is included as I got space on 160 X100 euro card.
I hope this may be useful for Music loving population which may not have test gear avvaliable.
I got a first PCB in the bath at the moment and as soon as tested I will take this forward
Old 17th February 2013, 01:59 PM   #8364
Bksabath's Avatar
Is New Atlas PRO now capable of differentiate therminals on J FETS ?
Old one could not ....
Old 17th February 2013, 02:12 PM   #8365
Nope. You can measure it.
Make a simple preamp. Say a common source single ended BOZ with a gain of ten.
Measure frequency response one way and the other way around. One conection may be more extended in the treble.
That is the correct one. That is beacuse capacitance in one direction is a bit lower but not much. I even found J-Fets that where totally symmetric.
Old 17th February 2013, 02:22 PM   #8366
Bksabath's Avatar
Tank you Joachim
And apolologies for temporary Hi Jack of this tread
Here is Pre view of test all rig
Can pick 4 different voltages on the LM 317 regulators
Dill switches and IC sockets for now
Finished one will have rotary switch for selecting test feature and meter connections.
Old 17th February 2013, 02:36 PM   #8367
No regrets, that is useful.
Old 17th February 2013, 04:25 PM   #8368
There are some news on the Paradise front.
I talked to Hesenr today. He made some simulation what the big elcaps do at the input.
We already talked about that they have to setle down a bit to "form" so that the leackage current goes down. That has a direct effect on the output offset that gets a bit down with time. Ones they have settled and the real values and types are known he found a slight resonance peak at ca.80kHz that can be damped with a snubber. He is working on the values and we will inform you when that has proven to work.
It has to be seen if that improves the sound. We also talked about a new group buy of PCBs. There are some new and late commers and the issue is also discussed on the German Analog Forum. I also have an idea for a balanced Paradise that uses two PCBs per side for a total of four. A bit over the top but again there is some interest to explore that option.
Old 17th February 2013, 08:04 PM   #8369
RCruz is online now RCruz  Switzerland
RCruz's Avatar
Originally Posted by Bksabath View Post
Almost got spontaneous brain burn out caused by math symbols and 2 remaining brain cells being almost 50 proof.
Nothing to worry about.
In fact gm = 2 x (Idss / Vp) x ( 1 - Vgs / Vp)
But as ( 1 - Vgs / Vp)2 = Id / Idss
gm = ¦ 2 x (Idss / Vp) x sqrt(Id / Idss) ¦
So at Vgs =0 you have gm0 = ¦ 2 x Idss / Vp ¦
It is all the same.
RC
Old 17th February 2013, 08:22 PM   #8370
RCruz's Avatar
I will wait for that option before I continue populating my new boards
RC
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
