| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#8351 |
Custom made Heatsinks- COOOOL
B.t.w. luv da Smurfs
#8352 |
Here is the concept of the Cro Magnon Tube.
A volume control could be integrated ( or not ). There are 3 different versions that have their pros and cons. |
#8353 |
I have build an input stage that COULD work. DC conditions are rock solid so now i can try how much gain i can get out of it. I need a gain of about 300x to 400x at DC.
#8354 |
#8355 |
That song was used in the Lincoln car commercials. That's the only reason I know about it.
#8356 |
For whom it may concern (or be useful
) http://technologyinterface.nmsu.edu/...Fall09/011.pdf
Signature Transresistance Current-Feedback BIGBT Amplifier; Push -->>{{ }}<<-- there.
#8357 | |
RC |
#8358 |
i will study this, thanks.
#8359 | |
![]() Almost got spontaneous brain burn out caused by math symbols and 2 remaining brain cells being almost 50 proof. I was going to use this Transistor matching and would welcome same advice please If I place a 100 Hom's resistor where the picture shows the A meter I can measure volt drop across the resistor Yes? What would be the best value for the resistor? |
#8360 |
You have to make sure that the resistor does not drop too much voltage.
Say you use a 9V battery and the Fet has an Idss of 10mA. You want to drop 2 V. That makes the resistor U/I = R 2 / 0.01 = 200 Ohm Your 100 Ohm whould drop 1V. That is ok too. |
