MPP
MPP
Old 29th January 2013, 06:02 PM   #8251
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I am running this program on Bootcamp on my MAC so the Windows version is very basic.
I will look up if i find that tool nevertheless.
I have now measured BC327-40, 337-40 and also 1N4401, 4403.
The 337 is much faster then the PNP. The curves group only well under 2.5mA so the chosen idle for the Paradise is just about right. One advantgae of that trannies is the high Hfe giving relatively small base current. That helps with DC coupling of a common emitter stage like in the Paradise.
The 1N4401, 4403 combo is actually very good up to 4mA. The disadvantage i can see is less Hfe at a bit under 200.
Out of curiosity i measured BD139-16, 140-16 and they do very well up to 5mA.
I knew that from measurements that Sergio Santos made on the low distortion I/U converter.
Old 29th January 2013, 06:15 PM   #8252
The best pair i measured so far are the Sanyo 2SC3503, 2SA1381.
Very good up to 12mA, my measurement limit. They are also know for low Rbb`of under 20 Ohm. Sanyo are not making them any more but the Fairchild KSC replacements are reported to be as good. These are also great VAS driver and buffer trannis. Hfe is useful at a bit over 200.
I also tried the 2SC3601, 2SA1407 combo. They are famous for extremely low Rbb`of ca. 2 Ohm. Unfortunately they are not very complimentary. My pair had also low Hfe of around 80.
Old 29th January 2013, 06:28 PM   #8253
I also measured MJE15030, 15031. Early voltage is pretty high but all pairs i tested had a huge Hfe difference of a factor of about 2.
They have low Rbb`of around 10 Ohm though so i do not condemn them totally at the moment. Maybe i can buy some that are better matched Hfe wise.
Old 29th January 2013, 06:34 PM   #8254
I measured BD437, 438, the ones that JLH uses in his parallel symmetric MC head.
The main advantage of this ones is Hfe over 200, quite good for a medium power device.
JLH chose them because of this to minimize base current.
Not very complimentary over 2mA, not very satisfying for a medium power device.
The Sanyos have Hfe as high and match much better up to high idle.
Old 29th January 2013, 06:50 PM   #8255
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
MPP
Originally Posted by Joachim Gerhard View Post
Here are some screen shots of the curve traces. The last graph shows the BC550C, 560C pair. Up to 2.5mA the curves are congruent.
Very instructive findings.
Would you please plot a k170BL at different Vgs for me ?
RC
Old 29th January 2013, 07:08 PM   #8256
Sure, i also will compare a 2SJ74BL.
Old 29th January 2013, 07:34 PM   #8257
nhinstruments
RCruz's Avatar
MPP
I want a machine like that one....
RC
Old 29th January 2013, 07:42 PM   #8258
It is really not expensive.
First i wanted to build a curve traces myself but that would have cost not much less and i really enjoy the time it safes.
Old 29th January 2013, 07:45 PM   #8259
smms73 is online now smms73  Portugal
smms73's Avatar
Very interesting Joachim, can you speak a bit more about Sanyo 2SC3503, 2SA1381, if possible some pictures
I was thinking that the pnp would be must worse than the npn (early voltage), at least in the fairchild datasheet it seems worse.
Thanks.
Sérgio Santos
Old 29th January 2013, 08:41 PM   #8260
smms73's Avatar
A problem with ksa1381 ksc3503 is that at this moment, there is only avaiable the hfe group D for the npn and the hfe goup E for the pnp, I will buy some for the amplifier that i am developing , and then I will do some measurements. But i will for shure use them as pré-drivers.
Sérgio Santos
MPPHide this!Advertise here!
