Mpp - Page 825 - diyAudio
Old 29th January 2013, 02:42 AM   #8241
Joachim Gerhard's Avatar
Actually the avalanche noise in BJTs is very similar to what happens in a zener diode.
Something like 6V Vce is optimal i think.http://www.electronics.dit.ie/staff/...seAnalysis.pdf
Old 29th January 2013, 02:44 AM   #8242
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Lets see about BC337 and 2N4401 then.
Old 29th January 2013, 02:47 AM   #8243
When more dynamic range is needed in an MC head i would then go for cascoding.
Anyway, in the Paradise we use more then 6V on the input transistors without cascode and the noise is reported to be very low. Maybe i am a bit neurotic and too careful to avoid noise.
It is a revelation though to listen to an ultra low noise phono stage although the mechanical noise is much higher. This is a bit like listening to a low distortion amp over a higher distortion speaker. Mechanical and electrical noise and distortion do not have the same origin and the ear can differentiate this i think.
Old 29th January 2013, 02:48 AM   #8244
I will measure them tomorrow.
Hopefully i am able to show some graphs soon.
Old 29th January 2013, 02:51 AM   #8245
Salas's Avatar
Its like when magnifying a dirty object. If the lens is good the object still has dirt but you know what dirt and where.
Old 29th January 2013, 03:50 AM   #8246
Somehow my system can put the dirt into other places in the 3 dimensional image where it does not disturb much and the music comes through non the less.
Scratches sound really "short" and occupy only a small space.
A good record cleaning machine helps tremendous.
Some really worn records are hopeless though but choosing the program material is part of the art of vinyl.
Old 29th January 2013, 10:14 AM   #8247
RCruz is offline RCruz  Switzerland
RCruz's Avatar
Here you see what we call in German " Kennlinienfeld".
It shows that the Vce curve against idle gets flatter when the idle goes down.
My BC550C and BC560C samples did even better.
http://www.htl-rankweil.at/grass/ftk...latt_BC547.pdf
I noticed the same behaviour in fets... looking at k170 data, http://www.datasheetcatalog.org/data...shiba/1027.pdf , Id - Vds curve shows a flatter line for lower Id, but that means a lower Vgs (-0.4v) and looking at the Id - Vgs curve, we need higher Vgs (near -0.1v) to reach the most linear region.
IMO, in this case the solution is to compromise, use a Vds higher than 8 volts and a higher Vgs (-0.15v)
RC
Old 29th January 2013, 05:16 PM   #8248
Here are some screen shots of the curve traces. The last graph shows the BC550C, 560C pair. Up to 2.5mA the curves are congruent.
Old 29th January 2013, 05:26 PM   #8249
Salas's Avatar
Few small high Hfe BJTs are going to prove great for symmetric without plenty of noisy degeneration or extensive paralleling with a Cob penalty I am afraid.
Old 29th January 2013, 05:39 PM   #8250
FdW is offline FdW  Netherlands
FdW's Avatar
Joachim, your pc comes with a tool called 'snipping tool', I'm sure that this will be easier to use than pictures
Copyright 1999-2017 diyAudio
