Mpp - Page 819 - diyAudio
Old 2nd January 2013, 12:21 PM   #8181
Joachim Gerhard's Avatar
I use that kind of decoupling too. Usually 220uF and 22 Ohm. The 0.1uF straight over the supply pins i found first at Douglas Self.
Old 2nd January 2013, 04:23 PM   #8182
MiiB is offline MiiB  Denmark
Nice papers thanks..
This is what we did to prevent oscillation in the high impedance mirrors of the paradise..
Old 2nd January 2013, 09:00 PM   #8183
Analog Devices: Analog Dialogue: Ask The Applications Engineer - 25
Old 3rd January 2013, 12:30 PM   #8184
FdW is offline FdW  Netherlands
FdW's Avatar
O.k. I posted this in the builder thread, I should have posted it here, sorry
Originally Posted by FdW View Post
And if you have some spare time, go-to Google.com (yes that one ). In the search-bar type the name of your favorite component (BD140? or (as I did here) LME49710). Then select 'Images' and be amazed . Looking at these images you see odd items (or just interesting ones), select one and have a look.
BTW this is what I found in the LME49710 search results opamp??
Old 3rd January 2013, 12:31 PM   #8185
I will look that up.
Old 4th January 2013, 08:34 AM   #8186
FdW's Avatar
There is a ton of good information in the http://cds.linear.com/docs/Datasheet/lt1115fa.pdf datasheet.
Old 4th January 2013, 11:14 AM   #8187
PMA is offline PMA  Europe
PMA's Avatar
Yes there is, but several local DIYers here have asked me for help for the reason that a phono preamp built according to the datasheet was oscillating. LT1115 may behave tricky, especially with additional buffer in the loop. So is AD797.
Pavel Macura
http://pmacura.cz/audiopage.html
Old 4th January 2013, 11:36 AM   #8188
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Are you refering to the paradise ?
If so what opamp do you suggest for the servo ?
RC
Old 4th January 2013, 11:52 AM   #8189
PMA's Avatar
No, I was referring to the datasheet that FDW has linked here, i.e.
There is a schematic of phono preamp with LT1115 and I was referring to that.
Regarding paradise, I have a feedback of one local DIYer here and yes, he says it is oscillating. But it is just one piece, no statistics available to me regarding paradise.
For servos, I use OP07, OP177 and OPA134.
Pavel Macura
Old 4th January 2013, 04:46 PM   #8190
http://digilander.libero.it/paeng/projects_frame.htm
Copyright 1999-2017 diyAudio
