| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#8161 |
I found an investigation about a CFB diamond buffer. The output stage certainly lowers distortion :Diamond buffers w. CFP outputs
#8162 |
This company makes a lot of J-Fets, also P-channel :Junction Field Effect Transistor J-FET from AMS from American Microsemiconductor, Inc.
i have not checked yet if some of them are useful for low noise audio. |
#8163 |
I got this message and have difficulties to use DIYAUDIO :Google Safe Browsing diagnostic page for diyaudio.com
Does anybody know about this ? |
#8165 |
The problem is being taking care of, already in another thread
#8166 |
OK; fine. I can use DIYAUDIO at the moment only when i manually override the message.
#8167 |
When you go to "Extras" in Firefox and click "Einstellung" ( dont know in english) and click "Sicherheit" (secure?) you have to remove the hook? for "Webseite blockieren wenn sie als attackierend gemeldet wurde " then it works . Its enough if only one picture in the hole forum is declaired as " attacking " .
Sorry for bad english , hth Dirk
greatings , Dirk |
#8168 |
The problem seems to be solved on a macro level. Everything back to usual.
#8169 |
Godt nytår..... håber Vi laver noget fedt i 2013...
![]() Øl er en slags GUD...!!! |
#8170 |
SkØl
