Old 11th December 2012, 04:18 PM   #8051
Originally Posted by Joachim Gerhard View Post
as, was that really single ended or parallel symmetric ?
I showed one stage folded cascodes a long time ago that had enough gain.
If you call a cascode single ended a folded cascode is single ended also, isn't it?
With single ended you have the problem that the high current in the folded cascode gives much too much DC over the transimpedance bass resistor. 50mA over 100kOhm is a lot.
Since the output of the folded cascode is at or near zero DCV I don't see the point here.
I don't choose a higher current in a folded casc. than I would in a regular one (of course
as seen for a single transistor).
Old 11th December 2012, 05:09 PM   #8052
Joachim Gerhard's Avatar
Input cascoded plus folded cacode or only folded cascode ?
Old 11th December 2012, 05:13 PM   #8053
Ok, color me stupid. We can set the DC voltage out of the folded cascode to a low value with the biasing arrangement.
Old 11th December 2012, 05:30 PM   #8054
I still do not understand. Even when we set the current low in the folded cascode, say 1mA, we still have the problem by Ohms law that too much DC voltage develops over the RIAA. This way ......
Old 11th December 2012, 05:38 PM   #8055
No, the collector current of the pnp transistor in your drawing has to be sinked
to the negative side in a current source (gain is too low without).
Old 11th December 2012, 06:00 PM   #8056
Ok, then we have a plus-minus supply. I did not think about this.
Somehow my brain can not connect single ended to a bipolar supply but why not ?
Old 11th December 2012, 06:05 PM   #8057
You should always work with split supplies in order to avoid coupling caps where possible.
Old 11th December 2012, 06:17 PM   #8058
OHH, JEE, one coupling cap less - one supply more, anyway itīs cool.
Old 11th December 2012, 06:20 PM   #8059
Do you remember FSīs phono i build him ? There you substituted a split supply with a single supply and it worked to my horror nevertheless.
That was the hat trick the other way around. The dove mutated into a cylinder.
Old 11th December 2012, 06:43 PM   #8060
At least two caps for stereo, and you need a negative supply for your opamp anyway?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright Đ1999-2013 diyAudio
