MPP
MPP
Old 3rd December 2012, 03:35 PM   #7861
Joachim Gerhard is online now Joachim Gerhard  Germany
Joachim Gerhard's Avatar
As far as i can see you get too little gain. One reason may be that the output impedance of
this alternative input stage is not high enough and the other is that the RIAA is much lower impedance then the one simulated by Sampler.
Old 3rd December 2012, 03:56 PM   #7862
Stefanoo is offline Stefanoo  Italy
Stefanoo's Avatar
no matte what RIAA I put on it gives pretty much same results.
I personally think that this circuit doesn not work like this, but I am wondering how come sampler was getting 60dB gain with his simulator.
What simulator does he use?
Which result is correct though?
If the voltage drops and everything looks alright I can try to build this but usually I don't like to build something that doesn't even show the minumum functionalities on the simulator though.
Any thought on this?
Stefano
Old 3rd December 2012, 04:35 PM   #7863
I will make more experiments today if i can make an input stage based on the proposed topology that has enough gain.
Two years ago i made a parallel symmetric version of it that worked very well.
I designed a very high output impedance, low noise CCS but i forgot exactly how that was designed. I will try to find it in my files but i may need some hours.
There is a ton of circuits i made the last 5 years.
Old 3rd December 2012, 04:43 PM   #7864
Stefanoo's Avatar
why is the current source here a concern?
I mean the cascade current source with LEDs is very low noise and high impedance as well.
My main concerns would be whether the topology works properly or not, in other words, if it puts out the gain is supposed to and is not inverting and has decent noise and distortion performance.
For some strange reason the proposed topology doesn't work on the LTSpice simulator.
Is there any volonteer that wants to check that out as well?
I can share my project file.
Stefano
Old 3rd December 2012, 04:45 PM   #7865
FdW is offline FdW  Netherlands
FdW's Avatar
MPP
Like this? Does not work (for now).
Old 3rd December 2012, 05:04 PM   #7866
Well, Sampler made it work. How, i do not know. Maybe he comes back on this.
In my book the gain is Gm x RIAA / output impedance of the input stage
I also though to add a folded cascode but then we have the problem that this amount of current ( say we run the folded cascode also on 50mA ) drops too much voltage over the
bass resistor of the RIAA. Say the bass resistor is 100kOhm, then we have 0,05 x 100000 = 5000 V !
Old 3rd December 2012, 05:05 PM   #7867
Stefanoo's Avatar
yep it is the same model I have and sampler has simulated.
I agree with you that it doesn't work and I would be astounded to see that such a simple circuit boosts 80dB with relatively low distortion, it would be the MOST minimal circuit you can ever think.
I would rave to try such a topology if it was working.
However I still don't understand why Sampler got that result.
Stefano
Old 3rd December 2012, 05:06 PM   #7868
Frans, your circuit does not work because there is only ca. 25mA idle in the input stage and your CCS delivers 50mA. That makes the voltage over the CCS break down.
Old 3rd December 2012, 05:20 PM   #7869
Stefanoo's Avatar
Good hint.
I got it to work on the basic idea. It is a matter of having the right amount of current droving on the top current source of the cascade.
Here is a screnshot.
Stefano
Old 3rd December 2012, 05:24 PM   #7870
Stefanoo's Avatar
However on dynamic behaviour, it is pretty odd.
Take a look at this:
Stefano
MPPHide this!Advertise here!
