| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#7821 |
Ok, cool. You took 3 x Bf instead of 4. 4 will bring the gain slightly up ( plus 1.5dB a assume ), so i am happy.
#7822 |
C5 could be even lower when a slight subsonic filter is wanted.
#7823 |
If it works then one of my dreams comes true, a one stage RIAA if we do not count the buffer.
#7824 | ||
This is output impedance without anything connected to output, so it's about 1.3M parallel to shunting resistor 130k in Joachims schematics. Quote:
I think I saw a thread couple years ago were very similar concept was discussed in great detail, where is that search button... Edit: Found it Great stuff with lot's of guru's
#7825 |
Sure, in the tube RIAA is use a tube cascode with 8mA idle.
On the other hand to build the input stage is not a big deal. Maybe i find the time tomorrow. |
#7826 |
Salas thinks that this circuit has not much to do with his Simplistic so i renamed it to Cro Magnon.
#7829 |
That was my first thought (:
A phono stage so simple that a cavemen can build it. |
#7830 |
Location: Scottish Borders - Kelso; on the famous Tweed River!
Well....I'm in then!
