Mpp - Page 772 - diyAudio
Old 13th November 2012, 02:41 AM   #7711
The Space Egg Corp's Avatar
Smile The Plot Thickens.....
Here's an interesting plot...
Si.
Old 13th November 2012, 02:47 AM   #7712
Joachim Gerhard's Avatar
Could you share your circuit ?
Old 13th November 2012, 10:21 AM   #7713
gk7 is offline gk7
A RIAA preemphasis test box using E48 resistor values:
Old 13th November 2012, 11:09 AM   #7714
Banned
Reverse RIAA is always going to be a compromise as long as we pick one to give consistent results across the pond I see no problem.
I am not going to fuss about 0.1 dB difference considering that before the sound get in to the groves it goes trough quite a lot of gadgets with loads of knobs (instrument tone controls mixing desk controls, pre-mastering "producer” tone controls master before cutting tone controls and here possibly a Newman pole that changes between each machine) then consider that each record came out at different times and was then tuned to the mass media typical sound system in use then ad this includes "gettoblasters"
So give me one that is easy to cook and stick to that. Algar did a lot of work so Hagerman is fine by me.
About Neumann pole Mr Neumann builds the lathes that cut your record to improve the reliability (arm breaking off and flying away) he added a resistor to make a further pole not all lathes have one and not all lathe have the same.
He himself was surprised by the use of his name for it.
Use it or not is a mater of taste but not a standard.
Old 13th November 2012, 11:16 AM   #7715
Mr. Neumann was long dead when Stereo records where introduced. Anyway, i think basically the same. Channel balance is more important then plus-minus 0.1dB RIAA precision, although that comes automatically with good channel balance. We have discussed this here anyway. Ricardo and Sampler came up with fine tunings of the Paradise with mathematical means that have shown that it can be set up with extremely good precision.
Old 13th November 2012, 11:43 AM   #7716
Here is some information about the Neumann pole :Cut and Thrust: RIAA LP Equalization | Stereophile.com
Old 18th November 2012, 05:27 PM   #7717
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Default Paradise PSU
Originally Posted by RCruz View Post
Hi
Can I use only one TX to feed two prereg psu´s to power the Paradise ?
I have one suitable TX that has double output windings and would like to minimize crosstalk using double bridges and caps, forming two psu´s.
I am afraid this might cause hum due to using the same TX secondaries to feed both bridges in parallel.
Following my initial quest about powering the Paradise with only one TX, I was lucky to get FdW full attention on the subect.
We have been working on this project in the backstage and finally agreed with a layout. I successfully built it and it works wonderfully. (One TX feeding double preregs to power both riaa boards independently and so got lower crosstalk from the raw psu).
During this work we also came up with a new grounding schematic for the riaa preamp and the TT that I believe can easily be implemented in any system.
I want to openly thank Frans for all the night work and inconditional support
RC
Old 18th November 2012, 06:01 PM   #7718
pdul is offline pdul  Denmark
Are you posting the final result, in one of the paradise threads?
Old 18th November 2012, 06:11 PM   #7719
Where does this scheme come from?
Thanks.
Old 18th November 2012, 06:16 PM   #7720
FdW is offline FdW  Netherlands
FdW's Avatar
As soon as I have some time (to give it the proper attention) I will publish it in the Mpp thread (about halve way next week I think).
Copyright ©1999-2017 diyAudio
