Old 12th November 2012, 10:13 AM   #7691
Joachim Gerhard's Avatar
If you like you can come to the L`Art du Son room and we have a chat. Would be nice to see you.
Old 12th November 2012, 03:14 PM   #7692
gk7 is online now gk7  Europe
Cool, CU
For anyone who might attend the Klangbilder show too, it´s room 334 (third floor).
Georg
Old 12th November 2012, 04:23 PM   #7693
Algar_emi's Avatar
Hi. I have a full set of measurements on the Paradise. Readings:
Gain: 61.4dB at 1Khz
Vout max: 30Vpk-pk
THD at 1Khz (Ref 1Vrms): 0.06%
Noise measured with HP3581A
Noise at 1Khz (input in 50 ohms, 10Hz BW): -99dBV (-92dBV in 30Hz)
Noise floor, see included picture, in red my Clio system noise floor, the white is the Paradise, input terminated in 50 ohms, no shield or enclosure, but using the pre-reg and RC-filter supply. First supply 120Hz peak at -74dBV. It will be probably lower with a separate supply enclosure, put away.
1Khz FFT spectrum. The supply noise is higher there because the preamp is connected to the CLIO system. I always have this kind of error in measurement of phono preamp. It will be lower with an actual cartridge.
RIAA Curve, see table included
Well close to text book perfect, with 0.2dB almost at all frequency. Since my signal generator is not perfectly frequency stable, neither perfectly flat in amplitude, these are pretty good results.
The Paradise has excellent measured specs. Now time to start building the enclosures...
File Type: jpg Noise_floor_Red-PC_Card_Wht-Preamp.jpg (119.8 KB, 155 views)
Old 12th November 2012, 04:45 PM   #7694
Algar_emi's Avatar
Here both schematics preamp and regulator with a lots of reference voltages readings. May be useful while troubleshooting your preamp.
File Type: jpg Paradise R3 schematic amplifier_notes.jpg (534.4 KB, 153 views)
File Type: jpg Paradise R3 schematic regulator_notes.jpg (573.6 KB, 140 views)
Old 12th November 2012, 04:57 PM   #7695
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
There is discrepancy from 1.5KHz upwards between channels. What is better to mod for that? Some impedance ratios, or the 11n caps?
Old 12th November 2012, 05:13 PM   #7696
I would tune the caps. To get a handle on the output impedance of the mirror is harder.
Old 12th November 2012, 05:14 PM   #7697
Algar, i see mostly PSU harmonics. That should go down a lot when the circuit is in the cabinet plus correct shielding. Otherwise it looks good.
Old 12th November 2012, 05:18 PM   #7698
Salas's Avatar
Open loop blues...but hands on, we like hands on.
Old 12th November 2012, 05:20 PM   #7699
FdW is offline FdW  Netherlands
FdW's Avatar
To PSU looks perfect to me. The preamp also (but that’s not mine to judge ) Most of the mains related peaks will be gone if the measurement equipment is disconnected, when the RAW PSU has its own box, and when the preamp has its own box. (as Joachim noted)
Old 12th November 2012, 05:49 PM   #7700
MiiB is offline MiiB  Denmark
Algar...
you have to get rid of the hum....!! all the harmonics you see at you FFT is from the 60 Hz hum you have..
And when you measure the Paradise you need to terminate the input with a lower resistor. the 50 ohm termination has more noise than the stage in itself.
But I agree, these are a clear hint of the technical qualities of the phono-stage...Not too bad..!
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
