Mpp - Page 765 - diyAudio
Old 7th November 2012, 09:05 PM   #7641
RCruz is online now RCruz  Switzerland
nhinstruments
RCruz's Avatar
So you connect your TT chassis to mains earth and also to the riaa amp case ?
RC
Old 7th November 2012, 09:20 PM   #7642
Joachim Gerhard's Avatar
Mostly i play prototypes without case. I connect the tonearm ground wire to a star earth usually and from there i do a wire to the turntable chassis so in my system everything is connected to main earth. I may have an unusual quiet earth though because my listening room is on the ground very near a long copper pole that is buried into the ground.
My main power for my system has a separate wire and silver fuses and special hall effect circuit breakers that are not in the signal chain.
Old 7th November 2012, 09:24 PM   #7643
nhinstruments
RCruz's Avatar
But do you reference your riaa amp circuit to that mains earth ? Or do you leave it floating without any connection to the tonearm gnd wire ?
RC
Old 7th November 2012, 09:28 PM   #7644
Today i visited Mundorf. They gave me some new toys, silver-gold wire and the new cute EVO caps. We had a discussion about teflon caps and so far they are not happy with the tightness of the winding. Also copper foil sounded worse then metallized aluminum. They think because mechanical stability is more important. Pick your poison.
Thanks Raimund and Mirco.
Old 7th November 2012, 09:28 PM   #7645
I connect the tonearm wire to the RIAA ground too.
Old 7th November 2012, 09:30 PM   #7646
toys....
Old 7th November 2012, 09:31 PM   #7647
nhinstruments
RCruz's Avatar
And that riaa ground ( circuit ground) is also connected to mains earth ?
P: Like your new toys... a lot
RC
Old 7th November 2012, 09:35 PM   #7648
Yes. It works in my system but it is important where the star ground is.
With stereo it is simple, i use batteries mostly anyway so i do the star between the batteries. Double mono is more complex. Honest i play around until the hum is gone.
Even a small hum can totally destroy the bass performance. Dead quiet is mandatory.
Old 7th November 2012, 09:37 PM   #7649
Benedetto's Avatar
So at least for you is early this year.
preregulatorpeterE-MAIL
Old 7th November 2012, 09:39 PM   #7650
I do not know why but i get a lot of samples from a lot of companies. Maybe they think i have good ears ?
Copyright 1999-2017 diyAudio
